That's Insane
Holdmybeer
Jayco
Alante 31 AL
32’
F53
6.8L V10
Nissan Frontier Pro 4X
Earlier this week I drove up from Dallas to Golden, Co. to pick up a 20' sailboat. The trailer had 12" bias ply tires load C which were rated for a maximum sustained speed of 65 mph. Which on the 800 mi return trip was excrutiating. Back in the DFW I drove over to Northern tool intending to buy a couple of premounted radials speed rating M or N. I found what I thought were 4.80-12's marked High Speed Radials ( Kenda- Load Star) However there was no speed rating indicated, just "High Speed" and load rating C. The store mgr. came over and said they were indeed radials and the load rating means they can be driven at high speed ( not even) and besides " High Speed" is relative. Then I pointed out to him the sidewall psi at the max load was 90 and no radial trailer tire is going to be run at 90 psi. Come to find out, Northern Tool has been falsely claiming their Kenda bias ply nylon tire to be radials and the "High Speed" on the tire sidewall actually means only 65 mph, exactly the same as their regular non high speed version of the tire, which is exactly the same tire. Problem is if someone throws those seeming radials on a trailer at max load and goes screaming down the interstate at 80 mph they're going to overheat and explode. Probably an honest mistake, but they sure should fix the screw up there. The store mgr. walked away convinced I was just another confused customer.
No problem for me 'cause I wouldn't be towing a 20' anything down the hiway at 80 mph!
Edit: I guess I should have more light in the room when typing. I too would put the 20" items in the back seat 'n let 'er rip!
What is insane is that somebody would want to tow a 20' sailboat faster than 65mph.
Going down the freeway with tires of any kind at 80mph is truly insane.
There’s about 7 million insane folks in the DFW then. They change tires at 65 mph around here.
"Did you ever notice that anyone going slower then you is an idiot and anyone going faster is a maniac" George Carlin
I never said I was going to pull a boat at 81 anyway. I said I wanted a tire rated to tow at 81, that way I can comfortably cruise at ~70 and punch it if need be. Ordinary 8" and 12" bias ply tires are rated to cruise at no more than ~65. They're turning a lot of rpm. and run at a higher temp than a larger diameter tire would. I have one boat trailer with 8" bias ply, I try to hold it back to ~60. The Melgis 20 Scow I pulled back from Denver only weighed ~600 lbs and the trailer was probably 3 or 400 on 12" tires. I didn't have much of a load on the C rated tires but it was 101° through New Mexico and NW Texas and I was concerned about overheating the 65 mph rated tires.
I had 1 trailer with 13 in tires.
I dont trust fast spinning little tires so i moved the fenders to clear 14 inch radials
I believe that you can drive any speed that you feel is safe and the trailer is tracking. That post was not meant for you, but meant for levity
As for me I get tired of everyones "opinion". Like when they get mad or exclaim outrage if someone drives their rv more then their, completely made up, 300 mile/3 hr rule. I drive my ability, not some made up rule that the "believers" get indignant about. Just because they have no stamina or ability does not mean everyone else does not.
You do whats comfortable to you, whether its 45 or 85 as long as its safe for all of us.
Yeah, I was looking for 12” radials, but hard to track down.
