Alert Battleborn battery safety alert
  • Thread starter Thread starter Neal
  • Start date Start date
  • Featured
@Richpatty - I know and I hate airing stuff that could affect someone's resale but it's not like everyone doesn't already know. I posted the above video as it's another something against the company suing Will Prowse and I hope he is hugely successful in the end. I'm sorry if it affects you, resale values already suck, I doubt it's going to make a difference. We both have great coaches, it's far more beneficial to just enjoy them as best as we can and appreciate what we have.
No worries at all…. And I had heard of the suit against Will, which is wrong and kinda stupid. But that’s business.
In the grand scheme of things, my BB batteries will not probably make a difference…and I could replace them with another set at a fraction of the cost if it made any future buyer happy.
You and I both could avoid the "set" and use just one like @lostinfla did. I tell ya, I had to twist his arm and he sure got it right and outdid us both :)
Check your batteries for loose post or singns of swelling. If apparent, call battle born.
You have not been following along. BB does not care and cannot afford to replace them as they have no money. Its a safety"feature" and you will have to buy new batteries. You must have abused them.....
Honestly, most people are totally clueless when it comes to battery abuse. Doing the math, consider that a 3000w inverter can draw 250 amps. If we consider BB 100ah battery is now rated at what? 40 amp draw that equates to 7 BB batteries, to handle the full capacity of the inverter (not temporary peak demand).
The specs should be studied for whatever battery brand you select, if you don't want to abuse your batteries.
I stick with LA because abuse might distroy a battery, but they are less likely to become a Roman candle.
Lithium does not require venting. Another plus to them as you can put them inside the enclosure and not have them in the elements.
You may someday be surprised. Have a cell or two short outs, make some hydrogen gas, and light it up. Even if you do not have propane a flammable gas, propane detector should be in place with any form of lead acid battery.
Good points for FL, mostly droping the plates happen with high impact installations ie. Four wheel drive Boulder crawlers,, or crazy driving in general, I have lost a few. My system uses TFLA carbon lead tech AGM batteries. Cell shorting is highly unlikely, but it could.
Propane (yes I use it) detectors when located properly are placed low to the floor (propane is heavy and drops). Hydrogen is light and would require a detector toward the ceiling, would be different technology. But with battery plates securely sandwiched between fiberglass mat shorting the plates would require an act of a recessed Congress. And with the government shutdown, I suppose that would be possible, but still unlikely.
I assume with the defense,you use lithium tech. If you think it's best,you don't need to defend it. If you are having buyer's remorse, then maybe you should.
Kevin
He's not stopping with the lawsuit, more Battleborn info and testing:
Battle born will not survive this
