- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
In reading this thread on anti-sway hitch tighteners I noticed @Tjdave like me was not using locking hitch pins. I used locking hitch pins on the tow bar and the toad when I started out. They became a real pain on the toad side especially as a newbie finding myself disconnecting/reconnecting far too often getting myself into places I couldn't maneuver in. Later stories came about regarding RV fires and fires that actually started from the TOAD (vehicle being pulled behind a motorhome).
I learned from the fire stories that there is a possibility of saving this situation if I did not use locking hitch pins. My rear view camera is always on so I'm always monitoring my toad as well as traffic behind me. If I saw a fire in the toad I could immediately pull over and pull the pin and disconnect the safety cables from the RV side and hopefully drive away from the toad will little to no fire damage. It may or may not work depending on the risk of the toad fire and explosion of course. The counter is some kid pulling the pin out or it coming out, who knows, but this has become a routine part of my inspection that I call out to myself prior to departing.
FYI
P.S. this also came in handy when I had to have engine work done with rear access, they needed the tow bar off. Don't forget about this if you take it in for service.
FYI
