How To Power Starlink Standard (Gen3) using PoE?
@DavidL you mentioned this product to power a Starlink Gen3 "Standard" setup.
This appears to just take a 12V source and not require a 120V power supply?
Looks like a great option!
Yes, it takes 12 volts and pumps that up to POE voltage (57 volts? memory is failing). It also has lightning suppression built in so less chance your electronics ecosystem fries when near a lightning strike.
Then, it's "normal" ethernet DHCP server/ firewall / routing etc that takes place in the existing router (like PepWave, or PFSense or many others).
All of my core networking runs off of 12 volt natively so less power efficiency losses (not that I care too much about that as I have never dry camped). My real reason is same dish gets relocated to boat, car, house so I don't need multiple monthly Starlink service charges.
The Starlink service plan is associated to the Dish, not the router so the router that Starlink provides is optional.
Note that the Starlink would typically be connected to the WAN (dirty side) of the router's firewall.
Excellent. While it allows you to remove the Gen3 Wi-Fi router it still adds a router but 12V powered appeals to me for boondocking. However, my inverters remain on so I have to see if I get any other benefit going this route. I do use an Amazon Alexa enabled smart plug on the Starlink router so I can turn it on/off as desired. Options to consider. I have just have to figure out pro's/con's of 12V power vs. inverter supplied power via 120V.
If your inverter inverts power at 95%, then you gain 5% more battery life by not using the inverter.
Good to know. Thanks!
I have used a home made POE for my Gen2 StarLink, which required some effort. It was flawless and allowed me to get rid of all the extra equipment.
One of the reasons I did this was the distance from the clearview sky to the RV was approx 500ft. I mounted a solar panel, 200Ah of battery (lithium), the POE, and Ethernet to fiber transceiver equipment in the box and raised the starlink on a 50 ft pole to get clear sky. I then ran fiber to the RV and converted back to ethernet at my peplink.
This has worked very well for the past 4 years. The setup runs year-round, even when I am not camping, as it provides monitoring of the cameras and other devices we keep there.
When I installed the large in motion unit ($2500 setup), I didn't recreate the POE, and I doubt the effort would be worthwhile for this dish. It is a very large power consumer.
is the 50 ft pole for the sticks and bricks or also for the RV? Certainly telescopic. Gotta pic / link to the pole? Curious.
It’s on the property. Just some 1.25in metal pipe with guy wires to keep it steady. It’s in a forest so I had to get over the trees. It was 5 10ft sections with about 5ft in the ground with cement then 3 guy wires at the lower portion of top bar. It’s not perfect but was quick and easy.
@redbaron how did you set up the in motion dish?
I mounted the starling in front of the middle air in the center of the coach. I used VHB tape along the base when attaching to the roof and then used 4 screws into the aluminum cross bracing of the roof to add extra strength. It will not be coming off without extreme effort.
Once it was attached I used liberal amounts of Dicor over the heads of screws and along the edges of the bracket to ensure no water intrusion to weaken the tape or eventually follow the threads into the roof.
The cable was routed along with my cellular and other cables to the front cap and into the driver overhead cabinet. I mounted the starling POE to the ceiling of the cabinet, covering the 2"x3" hole I made to find the dang cable. This location had AC power, so it was very simple. I then ran an ethernet from that box to the side cabinet over the driver where my peplink is installed, connecting it to a WAN interface.
I have parked in areas with trees and it still works very well.
While I am at my property in MT, I use the RV based unit along with the Ground based unit I have there, my wireless internet from MT Sky, and AT&T. This ensures I always have plenty of bandwidth for the 6 people that like to use it during our summer stay :)
@sheridany the best way to get your high performance in motion dish dialed in is to move it around while your wife runs speed tests. You should hold it above your head and run in 10 circles one way, then run 10 the opposite way. It's best to diagnose issues by having this setup procedure videoed so maybe setup a phone with the video recording and then we can help you dial it in even further once reviewing the video. We are here to help!
I got a better way. Hang on!
bus GIF
I completed this mod today to install the 12V PoE injector for my Starlink Gen3 into my shore power bay. My prior Starlink cable was routed through this bay to the WiFi controller so I figured I'd use the same bay as it has the grommet to make passing the starlink cable out the basement simple.
I had an open spade in the 12V panel behind the cord reel so I ran a power lead (red) to a spade. I wasn't sure what size fuse to use but based on the 150W power spec and then using 12V the math comes out to 12.5A so I chose a 10A fuse. Now reading the Amazon page for the product and the specs it appears 15A is the correct fuse size to use so I'll change that next time at the coach.
I also used a rocker switch inline so I can easily turn on/off the power to this PoE injector so I'm not using power for this device when I'm not using Starlink which will be the majority of the time as cellular is my primary.
Easy install and will keep things simpler as I don't need the Starlink Wi-Fi as this is routed to my Pepwave's WAN port via the ethernet cable I ran down the half bath to the basement which wasn't hard.
Parts used:
PoE injector for Starlink Gen3
Rocker Switch
I designed and 3D printed the rocker switch mount.
This is the first time I'm breaking out the Starlink Gen3 to give it a try. Really don't need it here but glad I tested it before I needed it. First thing of note, the Starlink app calls it "Standard 4" and after some research it's the same dish as Gen3 apparently with a newer Wi-Fi setup.
The PoE product recommended in this thread for Gen3 doesn't work, sadly! It's also no longer on Amazon, probably a reason for that! So the newer option on Amazon here is a 200W version where the old one was 150W and obviously insufficient to power the dish Gen3/Standard4 via PoE.
I got the new one today, wired up, backed it with a 20A fuse, and it works great. Chat GPT recommended a different one though, so I did order that one which is 350W and seems to be a more professional model to use.
I also found my Flagpolebuddy Gen3 dish pole mount which I know they 3D print was poorly printed and the locking bar was broken off. Amazon sells this one which is aluminum and is working great. I'd much rather have a metal adapter than 3D printed.
Sadly Elon is not competing with my Pepwave BR1 Pro 5G (TK - x62's) which is pulling 350 down on Verizon 5G where Elon is only doing around 50'ish on average.
starlink is very overloaded at the moment. The new genaration of satellites will fix this, but until then, you are expecting 50-70 down and 5-10 up. Very stable, but does not compete with T-Mobile cellular for raw download.
