- Nov 3, 2019
- London Aire 4551
- Spartan
- 2020 Jeep Wrangler Unlimited Rubicon
I really think that proper cleaning procedures help. With the remote operated tank valves, I have been leaving the gray tank closed normally and draining when full, just like the black tank. Doing that seems like it would help with the tanks buildup, etc. Just theory, as I have no smells in the RV. I don't get on the roof to sniff the vent holes. I assume they will smell, and that my ventilation system is working properly.
Yes, I run the sanicon remotely as well.Are you able to turn on sani-con remotely? I think a 3" plumbing setup and stinky slinky provides a good vortex for cleaning while draining. With sani-con setups I think the sani-con should be ON to provide the same effect to clean on dump. I set my remote drainmaster setup to also include a remote sani-con control.
My DW suggested the same thing....I am curious, just not that curious.@redbaron you need to poop in your peanut butter jar and try your experiment again.
I nominate you to tackle this one..If you want to avoid the embarrassment, maybe dog or cat poo if you’ve got some of that lying around. Poo is poo.
