Question Tow Vehicle
djurden
Brenham, TX
Crossroads RV
Sunset Trail
37'
I have a 37' travel trailer that weighs ~7,000 pounds. I am currently towing with a Ford F250 Super Duty. I am considering trading it in for a new F150 3.5L EcoBoost, long wheelbase, with the necessary towing package. We travel quite a bit; approximately 12,000 miles in a year. Some of this is mountain driving; Colorado, Utah, etc.
I'm wondering if anybody has experience with the F150 towing this size of a TT and can offer some advice.
37' is too much trailer for a 150/1500. That's going to push the truck around like crazy, especially in the mountains or in high winds.
Why are you looking to get rid of the F250?
Maintenance and fuel costs. I just paid over $100 (~19 gallons) to fill up on diesel!
In that case, I'd recommend a gas 250/2500 for that much trailer.
Agree with Rosy: I've tried the F150 on a Flagstff Super lite which has a dry weight of 6700, even with the tow packages the F250 was much better. The F 250 has larger axles, bigger brakes, and stronger suspension parts, get the gas model you will be happier with that.
Thanks for your suggestions. I have ruled out downsizing to a 150/1500 class truck.
But I also just had a discussion with my wife, and we decided to keep our F250 Diesel for now. It is a 2016. We have had to replace the transmission, radiator, turbo intake assembly, and a few other smaller things. The engine is fine (133,000 miles) and have no other issues with it for now. So... unless something major changes, we plan on keeping it.
How much fuel could you buy after
You have an accident?
You burn up the brakes?
The Turbo or transmsission fails?
The engine fails?
What is the value of your pice of mind knowing that you have right rig for the job?
How much per 100 miles will you really be saving?
Since needing the transmission consider that maybe even the 2500 was not quit enough.
Drive less, enjoy more! Hopefully this mess will pass.
I don't think I have ever seen a 37 ft. trailer that only weighed 7000 lbs........is it hollow tube? My 26 ft Jayco was 7000 loaded, but 10 ft shorter.
Dry weight, maybe? My 25' trailer is 5500 dry, 7500 GVWR.
