Oxidation
Garyd
Ellensburg, WA
Forest River
Wildcat
Aluminum
My 2013 Forest River Wildcat trailer has been sitting outside all its life and somewhat neglected. Now I am cleaning it up and going through everything to get it ready for a trip. My question is how to remove oxidation and get the gloss back on the exterior. Any tips would be appreciated. I talked to the local RV place and they want $1500 to clean and polish it. Thanks!
It takes a lot of work to get a gloss back and then a good quality wax is a must. $1,500.00 doesn't sound out of place to me. You can do it yourself.
You will need a random orbital polisher (and don't cheap out. An inexpensive one probably won't last long enough for one pass). I have two. A six inch and a ten inch both with foam pads. I don't like wool. A good quality cut polish. I have used Meguiar's Marine. It works well. I also use Meguiar's Marine Wax. So now you have spend almost $1,000.00. All you have left to do is spend about two days getting the job done. Just an FYI, be careful and don't overheat the gelcoat. Don't let the polish dry out and harden, Don't press hard on the polisher. Let the machine do the work. Be carefull when you come close to mouldings and trim. You can easliy tear the foam pads.
Meguiare's ultimate compound should bring it back to a shine. Depending on how bad you will not need a polisher. Never tried Meguiare's Marine wax, but it sounds promising. I prefer to polish with "Glare" Polish after using Meguiare's ultimate compound.
I vote for $1500, after 2 shoulder surgeries, no more wax on wax off for me
I'm with you. I still have the tools but two days on a ladder doesn't fly for me anymore. I'll have mine done when I'm in Mexico this winter.
