Oxidation
Garyd
Ellensburg, WA
Forest River
Wildcat
Aluminum
My 2013 Forest River Wildcat trailer has been sitting outside all its life and somewhat neglected. Now I am cleaning it up and going through everything to get it ready for a trip. My question is how to remove oxidation and get the gloss back on the exterior. Any tips would be appreciated. I talked to the local RV place and they want $1500 to clean and polish it. Thanks!
It takes a lot of work to get a gloss back and then a good quality wax is a must. $1,500.00 doesn't sound out of place to me. You can do it yourself.
You will need a random orbital polisher (and don't cheap out. An inexpensive one probably won't last long enough for one pass). I have two. A six inch and a ten inch both with foam pads. I don't like wool. A good quality cut polish. I have used Meguiar's Marine. It works well. I also use Meguiar's Marine Wax. So now you have spend almost $1,000.00. All you have left to do is spend about two days getting the job done. Just an FYI, be careful and don't overheat the gelcoat. Don't let the polish dry out and harden, Don't press hard on the polisher. Let the machine do the work. Be carefull when you come close to mouldings and trim. You can easliy tear the foam pads.
Meguiare's ultimate compound should bring it back to a shine. Depending on how bad you will not need a polisher. Never tried Meguiare's Marine wax, but it sounds promising. I prefer to polish with "Glare" Polish after using Meguiare's ultimate compound.
I vote for $1500, after 2 shoulder surgeries, no more wax on wax off for me
I'm with you. I still have the tools but two days on a ladder doesn't fly for me anymore. I'll have mine done when I'm in Mexico this winter.
Thank you for the reply. I think I'll just try to clean up a small area and see how it goes. I might end up taking it to the RV place, but I hate spending money if it is something I can do myself. I've always been hesitant to use a buffer considering the damage that I could do. Anyways, thanks again.
No worries. I did mine for years. Age has crept up on me and I no longer have the do it yourself passion anymore. It is a time consuming job. Start by hand on a small inconspicuous area. Use a very slightly damp cotton cloth working in a circular motion. A power polisher does make it go a lot faster. The trick is to let the machine do the work. Don't press too hard. Keep it small. Chose a cloudy or cool day so the the compound doesn't dry too quick. Here is a YouTube link. I'm not sure he is a pro. I work smaller areas than he but It will give you the general idea.
Good luck.
