Winterizing a 2023 Bay Star 3408 for the first time
cayuga
Hi,
I have a 3408 with a washer/dryer and 2 door fridge with ice maker. I'm trying to winterize it and the manual isn't as explicit as I'd like. If anyone has any tips/hints/warnings/instructions, please share!!
I had created step by step winterizing instructions with photos for my 2016 Thor Vegas, I'll probably do the same with the Bay Star once I'm convinced they are complete and I'll happily share them here.
Thanks,
Jeff
I don't have an icemaker in mine, so no help there. I can't imagine it requires much more than using the dispenser to pull the antifreeze through it. Otherwise, it's a pretty straight forward operation.
Drain tanks, low point valves and water heater. Remove the water filter. Some choose to blow air thru the system; I personally do not.
I fill up the filter canister with antifreeze.
Bypass the water heater and pull the antifreeze in via the water pump.
Run all taps until they flow antifreeze, including the shower and toilets. I start with the rear bath and shower as its the farthest from the water compartment.
Pull antifreeze into the washer tub, be sure to use a warm setting or do Hot and Cold separately so that both fill lines receive antifreeze. I pour some additional antifreeze directly into the tub and then start the spin/drain function until all the antifreeze is gone.
I'm going off memory, but I think I got it all and i'm sure others will clue me in if I have forgotten something. I have a checklist and video in the coach to refresh each season.
Thanks! I've drained everything I could find (red/blue in water bay, low point drains under water heater and in the compartment next to it) and the Aqua water heater as well. I also removed the water filter.
Where is the water heater bypass?
You mentioned "canister" what/where is that?
Also, the instructions from Newmar mention a blowout plug. I don't think I have one -- suggestions?
Thanks again!
Thanks again!
It looks like my local (14 miles from here) hardware store has blowout plugs. Heading out now....
My hot water bypass is on the inside right by the tank which is under the kitchen sink.
My water heater is accessed from the last compartment on the passenger side.
I do not have aqua hot; I have a 6gal electric/propane water heater.
The water filter canister is in the wet bay. When I pull the filter, I fill the canister with antifreeze before reinstalling.
My hot water heater is just above the last compartment on the passenger side. I'll look for the bypass valve there.
I did look under the kitchen sink and didn't see anything that jumped out at me as a hot water bypass valve
Thanks everyone!
Jeff
Be careful blowing out the lines. Using high pressure compressed air can cause damage. Limit the compressor output to 60 psi.
To winterize the icemaker/ dispenser just remove the fridge water filter and dispense water until you see pink in the glass.
As far as the washing machine run a rinse cycle until you see pick and then drain the tub.
Read the owner's manual for the washer and the ice maker, they usually have better instructions than the manual for the RV overall. Not great, but better.
When it comes to blowing out the lines, CFM is more important than PSI. We usually limit the pressure to the standard water pressure which is 50 lbs or less, but we never just blow the lines out, we also follow it with the pink stuff.
Everything gets pink stuff because we were liable for the customers' rigs, but as the owner you can do what you want.
If you look inside the refrigerator door on the sidewall there will be a silver sticker with all of the model information on it. If you can post a photo of that sticker or at least the make and model of the refrigerator I will see if I can find the service manual for you, and that may have better instructions on running the ice maker.
Thank you!
I have found the water heater bypass and have drained and bypassed the Truma AquaGo.
I found the antifreeze intake (see picture) and flipped both valves and turned on the pump. It sucked up 4 gallons of antifreeze before I stopped feeding it. I didn't see pink stuff anywhere and opening taps yielded nothing. Where did the antifreeze go? What did I do wrong?
FYI - the cat litter bucket is there to protect the slideout control board.
Fresh water tank?
