Winterizing a 2023 Bay Star 3408 for the first time
You've got a newer model with the funky serial number. I don't see my service manual for the N10LX, but here's the training manual for the N1095, including N6's, N8's, 12xx's, etc, and not much changes between models in a series. This includes the cycle instructions for the ice maker if you want to force it to feed a batch for winterizing.
Thank you!
You do realize that is not the optimal way and you need to figure out the proper way to draw antifreeze directly through the winterizing hose to the pump while closing the feed from the fresh water tank. That pink stuff is expensive, I can do my whole system with one gallon but will use another 1/2 gallon for safety's sake. (respectfully)
Thanks everyone!! I believe that I have successfully winterized my Bay Star.
I'll try to organize my notes/photos and share them in a week or so.
YES!! I plan to figure it out in the spring with water instead of expensive pink stuff!
Usually there is a setting in the water input area that says "winterize" and shows the position of the many colored little levers. Unless you don't have this?
The AC does not have a convenient option to suck pink stuff into the water pump, so I bought 12 gallons of the pink stuff and dumped 10 gallons of it into the fresh tank, then distributed it around the coach, and used the last 2 gallons to service the city water inlet and the vacuum breakers for the black and grey tank flushes.
Compared to what it would cost if the unit froze up, the pink stuff is cheap, cheap, cheap.
$3.98/gallon is really cheap insurance
I just set the heater at 45° and don’t worry. It’s plugged into the house so I turn both electric elements on and done.
