The easiest way to boost a mifi signal
Underboss
Titusville
Dutch Star
2020 Blazer
Neighbor is using a T Mobile mifi. He wants to boost the signal at campgrounds and has no clue, as I do not either. My t mobile mifi works well. Anyway, whats the easiest way to get a better signal to his t mobile mifi? Thanks
Which signal does he want to boost, the incoming cellular or the outgoing wifi?
T mobile works in places ATT and Verizon won't, like my hunting area. I would guess it is his wifi or hotspot?
He has a MIFI, a hotspot. He wants it to supply a more stable internet connection. Apparently he loses his tv apps and has to log in every few days.
I told him SL but he is not there yet.
I would assume he wants to boost the incoming signal for stability.
In both cases, but especially with cellular, height and a clear line of sight is your friend, especially with 1800/1900 band which doesn't penetrate foliage or structures as well as 800/900.
If he has a 5G unit he might also want to set it back to 4G if he can, which in fringe areas can be more reliable albeit with reduced bandwidth, but still enough for TV. I can't see 1K let alone 4K, not sure about him.
Sometimes you can show a solid 5G connection with multiple bars of signal and still not be able to get a call through. Chattanooga/Ringold Costco parking lot comes to mind - great signal indicated, no data throughout.
Height is cheap or free and doesn't require electricity or a subscription..
After that you're into gadgets, and there are reviews on all sorts of those. His location will dictate what's best more than anything.
Yeah, we put a $350 cell booster on the roof of the hunting house in VA. attached it to a 10 ft pole and strapped it to the chimney. Pointed it in the direction the app told us to.....sucked. Then one of the guys got T-mobile this year and it worked great. But I had my Starlink Mini and it worked even better.
So if his device shows good signal and the Internet is lousy it's not the mifi it's the carrier. You can put a bigger pump on a well and if there ain't water in the well•••
If he isn't ready for starlink he's not ready to drink.
It's still not clear from the OP which signal needs to be boosted, as frequent drops and logins can be either one, and he is only assuming it's the cellular.
Well then perhaps both. I did state what was happening thats all I can state as its not happening to me but my, even less techy neighbor
None of anything, including a weBOOST and external antenna, will be as good as just swapping it out for the T-MOBILE HOME INTERNET router. It's, by far, superior for signal strength and total bandwidth, not to mention a heckuva lot CHEAPER to try! In fact, he won't be out any money at all, aside from the normal monthly charge which is nominal.
FWIW: Since the TMO Home Internet router and Starlink have come out, I've not seen or heard of a single weBOOST system being installed.
