Polson, Montana
ARD
Staff member
RVF Moderator
Fulltiming
London Aire 4551
Yukon Denali
  • Cellular device used: Pepwave MAX BR1 MK2
  • Cellular network(s): AT&T and Verizon
  • Cellular plan (smartphone or hotspot, postpaid or prepaid): AT&T postpaid, Verizon prepaid
  • Location and Time of Day: Polson Motorcoach Resort, Montana @ 7am MDT
  • Speed test results: AT&T: 77.7 Download/17.4 Upload; Verizon 17.5 Download/26.8 Upload
77 on att...wowsers!
You know, I could make a dead simple map app to collect this info and display it. @Neal would you host it? Just JS, HTML and CSS. DB will be in the clouds. I could also host it externally and you
could just iFrame it.
I prefer fast.com for speed test results. No bias
Powered by Netflix. No ISP sponsorship or advertising
I am not tech savvy, but after trying fast.com, I like Speedtest. I can't compare the Verizon and AT&T accurately with fast.com as they use different measurements (Mbps vs Kbps) and I'm not sure why the readings are so vastly different using Speedtest vs. AT&T. Why would fast.com use a server in Atlanta vs. Speedtest Helena, MT? This is so way above my head. The only reason I use Speedtest is to figure out whether Verizon or AT&T is faster so I know which one to put in the priority 1 position in my pep wave. ?
@9am MDT
AT&T: Speedtest: 60.8 Mbps Download/13.4 Mbps Upload
Fast.com: 3.4 Mbps Download/13 Mbps Upload
Verizon: Speedtest: .15 Mbps Download/7.98 Mbps Upload
Fast.com. 120 Kbps / 7.9 Mbps Upload
Fast.com is true ---non marketing speed.
Speedtest.com is paid advertising...aka fake results.
Technically the difference is fast test to Netflix servers, Amazon servers and other servers you use on the internet. No caching, no compression, no fake speed reports.
Speedtest only test the shortest path, and often never leaves the cellular data center. Fake results, bloated speed numbers that make you feel good but do nothing for you in real life.
Thanks. That is helpful.
Okay, but how do I compare if Verizon is measured in Kbps and AT&T is measured in Mbps? 3.4 Mbps vs. 120 Kbps?
Surprising Difference. Granted the test went to two different nodes but the download speed of my Comcast connection was 111mbps on Fast.Com and 180+mbps on Speedtest.com. And more important difference was the measured latency, 111ms as measured by Fast.com and 26ms on Speedtest. The upload speed was virtually the same, 11 mbps
1mbps = 1,000kbps
so Verizon is saying .12mbps? That’s awful slow. Not even good enough for email or browsing.
When we were at Polson last week I recall ATT was quite solid, Verizon crap, and the wifi was undependable, (and when it wasn't undependable it was pretty slow). That's my measurements from pete.com-very scientific! ;-)
You'd think with sites selling for 100, 300, 500k, (whatever they can get!) they could spend a bit of the profits or HOA fees on some decent connectivity. Maybe they local infrastructure just can't support it but geez!
I have to try Fast.com for awhile as I'm frustrated with speedtest.
@ARD I hope you got to meet a few of our fellow RVForum.com members during your stay. I think several were/are there along with TJ and Lady Di?
Latency! My brain is exploding. Okay, I had to look that up.
So redid the tests at 4:27 pm. Just AT&T, since Verizon isn't very good here.
Fast.com: 10Mbps / 11Mbps upload; Latency: Unloaded 41 ms/ Loaded 99 ms
Speedtest.com: 62.3 Mbps Download/13.1 Mbps Upload; Ping 116 ms
Okay, so if that helps ya'll, yay! For me, I just need to know which one works better. LOL. Thanks everyone for making me a wee bit smarter. Oh @MapNerd thanks for the conversion. I eventually would have thought of that. ?
Me too! I'm going to use both so I can get a better understanding. Thanks @redbaron for keeping me "in the know." @VTPete I have had a chance to meet up @TJ&LadyDi and @J&JD. It's been great hanging out with them. Also met up with a couple from San Diego that I met 2 years ago in San Antonio. What a great lifestyle. So much fun. Enjoy your time up there. I am jealous. Twice I've made the mistake of not staying at North American. Won't make it again. Will eventually write a review of the campground in Kalispell that I left this past Monday. ?
The att test on speedtest would suggest you can stream 4k HD. Fast.com test shows you cannot, but you can stream hd...which is excellent.
That puts things in perspective. Thanks. ?
Done yet?
