Chuggs
- Nov 3, 2019
- Ventana 4037
- 40’
- Jeep JKU
Just replaced my worn out Blue Ox coiled toad umbilical. When I did...no lights
Upon...further investigation the 6-pin end of the cord has a different pin outs for 12vdc+ and Trailer Brake.
Most folks only use the Running Lights, Left Turn/Brake, Right Turn/Brake, and Ground for their toads...but the Mopar Harness additionally uses 12 VDC+ to power the Toad lighting from the coach...and if the 12vdc+ isn’t present...none of the toads lighting will work.
Once I figured it out...it only took a few minutes to move a wire in the Blue Ox 6-pin receptacle on the Jeep end...and with the 12 VDC + getting to the Mopar harness...everything is working again.
Just thought I would pass this along for those using this setup...to avoid unnecessary grief.
