How long can a sewer hose be?
cwaweeks3
Due to these horrid fires, I will be living in my new rv parked at a relatives house. The trailer will be on the wrong side of the house from the sewer line of the house. Can I get a hose to go that far and still drain? The picture attached shows the rv circled at the top and the sewer line on the side. Any tips?
Depends on the elevation of the driveway compared to the sewer drain. These are the times when a Sanicon comes in quite handy.
There is no length limit for the hose as long as you have the trailer end higher than the outlet end. Keeping the tank valves closed until the tanks need dumping will assist with the distance.
As long as you have a continuous slope to the hose, distance is pretty immaterial. For the run you are looking at, you might consider running a 4" PVC pipe from near the RV to the sewer dump point. It could be run on the surface. The stiffness of the PVC pipe would help even out the slope. For a sewer run, you only need an inch or so drop per 10 feet.
Here in Minnesota, according to the state plumbing codes 4" pipe must have a minimum slope of 1/8"per foot (1 1/2" per 10 feet) and 3" pipe is 1/4" per foot (2 1/2" per 10feet). I would recommend that be the absolute minimum so that you don't have any solids stay while the fluids drain away.
Agree with the macerator. We park our MH in our back yard and on occasion need to dump at home. We bought a Flow Jet from amazon and a large hose from Home Depot and I just put it in the lid of the septic with no issues.
Flojet Macerator from Amazon
Install doesn’t get much easier than this. Just sayin...
X2 the FlowJet DKRITER provided the link too. I have that unit and use it at home to drain & clean my tanks after a trip. I've got 50' to the septic inlet which requires about a 12" lift at the inlet. The unit works great in my set up.
Probably the only way to go for a long run is 3" or if you have to, 4" PVC. A run of stinky-slinky that long would be pretty expensive and extremely hard to keep set up at the perfect drop. Visit any large plumbing outlet and you will find nice rubber fittings that are easy to use along with the PVC. Probably Lowe's and Home Depot will have everything you will need.
