F250 or F350 to Haul a 5th Wheel???
Thanks, Gronk. Did you have any passengers in the back seat of your dually? I have never owned a dually but I have been told that they are very stiff and you feel every bump. My girls 10/13 years old will be riding in the back.
The only passenger in the back seat when towing has been my 90lb Shepard/Spaniel mix. My brother said my 3500 rode better than his F-150 that he used to have, BUT I do have an air ride hitch and added air ride to the trailer, so I don't feel the bumps from the trailer. Running empty, it does have a little bit of a harsher ride, but that is a trade off for the more capable truck.
The mechanical difference between a F250 and F350SRW is very minimal. I pulled a TT with 2 different F250's and they were fine. I also had a box in the back that weighed a little over 1000 lbs and both F250's sagged way to much, I had to put on air bags on both to just level. When I went to the F350SRW the 1000 lb box had almost no effect on the suspension. When we bought a 5th wheel it only dropped it a few inches.
All this to say, if I was ever to get another 5th wheel it would be pulled by a F350 at least.
I had a Solitude 310GK which as 35 feet and 16,800 GVWR with a factory spec of 2240 pin weight and had 2017 Ford 1 ton with a payload of 3722 on the door sticker. On paper, it all was good but pulled it the trucker CAT scale and I was over the GVWR of the truck and within 200 pounds of the axle ratings. I plan to add in washer and dryer and generator. The 5er was within just over 15,000 pounds loaded ready to camp. Some of the 2020 and 2021 have more payload then in the past but don't believe what it says on the website. Spend sometime check the door stickers on Ford dealership and see the payloads can vary on 1-ton trucks buy thousand pounds or more. A 3/4 truck isn't enough truck PERIOD. The pin weight going to be between 20 and 25% of the and I would go with 25% when buying a truck just to give some margin. So 16,000 pounds time 25% would be 4000 pounds plus you have to add the weight of the hitch and people and stuff in the truck. Don't fall into the trap that I will travel lite. Check out this site TowingPlanner - towing capability calculators
Thanks, DKRITTER. There seems to be agreement to get more truck than less!
Thanks, Gizmo. Useful website, too!
Same boat but looking at the tow ratings, I did not feel comfortable going with a 250. You’re just too close to the line in my opinion and that truck is going to be working hard all the time.
We are finalizing our order tonight for an 2021 F-350 DRW 4x4 with a 4.10 LSD - rated to pull a bananas 34,200lbs (27,360@80% which I’d not think of exceeding). It’s the kind of truck where you just need to be pulling something very unusual to have to think much about your trailer weight other than making sure you don’t exceed your trailer’s limitations.
Edit: that was too glib of me. It’s a big truck and it pulls a lot, but there are still lots of things to consider carefully.
Just my 2 cents, Ford F-350, Super Duty, 6.7L Power Stroke, SRW Lariat.
Don't forget to weigh your trailer/truck combo, fully loaded, Before you hit the road!
Hello-
I would appreciate your advice on the size of truck to haul a 5th wheel.
We are about to purchase our first 5th Wheel (2018 Jayco Northpoint 377RLBH with GVWR 16750) for a multi-state 6month trip around the country with my wife and 2 daughters.
We are new to 5th wheels, but experienced campers/RVers.
We are looking for advice for the type of truck to safely haul this beast.
We've narrowed down to Ford.
Would you recommend an F350 or would an F250 be safe to haul up and down the mountains? Gas or diesel?
Thank you in advance!
The 2020 / 2021 F350 7.3 gas in a Dually configuration can pull 22,000lbs. I recommend a dually in any configuration. Also, as I have just learned, you should consider an air suspension to keep the truck - any truck - level while towing. Or, invest in a tire store somewhere.
