Pepwave Cellular Internet Equipment Installation
"EZ"
Internet Forum Junkie since there was dial up!
Ringgold, GA.
Holiday Rambler
Ambassador
40'
2019 Jeep Grand Cherokee
After I figure out what all I need to order to get my wife reliable internet in the RV, is there some place that I can get this stuff installed? I really don't want to try to figure it out myself. It'll take forever and would be much better for me to pay someone that was experienced to install everything. Would a local stereo shop know how to do this stuff? Or would an RV dealer be better? Where would you go?
That’s a tough one and ideally a shop that has done it a lot To start. You might try a small RV repair/upgrade shop that can demonstrate they have the know how and if they do satellite installations for dish or direct tv (or maybe even a WiFi Ranger dealer) would be a better choice as they probably know RV’s better since you are looking at a roof mount antenna most likely for optimal performance.
I don’t think you need to go to a shop quite yet. I don’t have a pepwave but I don’t suspect its much different from my MoFi.
  • Order the unit.
  • When you get it, set it up on your countertop, plug it in and follow the instructions that come with it to get it up and running. You’ll probably get a couple of Cellular Antennas and Paddle Antennas.
  • Get it running and do some speed tests. You’ll probably want to become familiar with some of the settings like Band Scanning and Band Locking because they will be things you need to use and adjust every time you move.
  • When happy, 3M it to your windshield, just below the tint line and behind the OHC. Let it sit there for a few weeks while you use it to help you determine if you even need external antennas. I haven’t yet. Doesn’t mean I won’t in the future. I expect to need them when I go west but here on the east I do not.
EZ,
I would encourage you to follow the suggestion offered up by MapNerd.
Setup of the equipment is fairly simple. Installation (permanent or otherwise), to include an external antenna, can involve a variety of factors. I've been using my equipment since May & still have not decided where a permanent installation will be. A lot of my indecision surrounds the placement of an external antenna on the roof & the location of the actual device in close proximity to 12 VDC & 120 VAC (for supporting equipment)., Then again, I also have to contend with a roof approximately 6" - 7" thick & placing the antenna so as to avoid signal interference from other 'stuff' on the roof. In the meantime, the paddle antennas have worked very well.
EZ, if you want to investigate a reseller, go to the peplink site. Certified Distributors, Partners & Resellers- Peplink
Momentum Telecom in Kennesaw is kinda close. Maybe give them a call. I would reccomend you get a quality antenna and roof mount it if you do a professional installation.
I like the suggestion of @VTPete since not that far away. Matter of fact I will be close to there11/24 and may stop by to get a feel on how knowledgeable they are. Or I will wait and get @Neal expertise in Casa Grande?
Happy to help in Palmcatraz @NWIP as needed. I think you should pick up some Drainmaster components so we can use my new ginsu set on your new coach!
Kennesaw is very close. About an hour away. I went through there today on the way to Atlanta!! I appreciate your willingness to help me with this. I don't want to over spend but I don't want to go cheap and end up having to buy this equipment 2 or 3 times to get what I really need either. I'm sure I'll be back asking questions............ :rolleyes: :rolleyes: :rolleyes:
  • Order the unit.
Mapnerd, what equipment are you running with the indoor antennas? I like the Peplink stuff but there's so many I'm not sure which would be the right one??? What do you have?
EZ,
Lemon Drop, what equipment package are you using? Are you happy with it?
Sheridany, what equipment package do you have? Are you happy with it?
Neal, I know you have the Mack Daddy of all setups and it's probably more than I need. I see you've upgraded a few times as well. Just curious, what do you do with your old equipment? Last years model so to speak? Can you trade that stuff in or do you have any you might want to sell? :LOL:
VTPete, what all do you have in your set up? Have you gotten the latest and greatest equipment like Neal? Are you happy with yours?
I don’t have any of the gear as I was trying to make some suggestions to find a place that could help you do the install. I think the others that offered advice of going slowly is spot on until you find the best solution for you.
Once I get my new unit installed and satisfied with the setup I'll sell my pepwave MAX BR1 MK2 and BR1 MINI (with wan license). Not sure when that will happen but these two units are awesome, I'm just doing a tech refresh but the performance of these are both great and ideal for 99% out there. I'll list them in the classifieds here when that time comes.
EZ,
I am using the Peplink Max Transit CAT-18. I have a Poynting 7-1 antenna which I will install once I figure out where. Supposedly the antenna comes with cables which are optimized (length of around 6') for the antenna. I made a conscious decision to go this route with both the CAT-18 & the antenna. Are there other options, of course. Some more expensive, some less expensive. Ballpark, I would say I'm into it around $1,200 - $1,300 for all including, activation charges for SIM cards.
I purchased my unit from MobileMustHave. Based on my experience, I would have no reservation in recommending them. They have an add on package where they will spend an hour or so with you via a Zoom meeting to go thru the set up of any unit you buy from them.
So far I am very happy with the unit.
EZ,
Have you installed your Mobile Mark antenna yet? If so, have you noticed any improvement in either cellular of WiFi performance? If you have installed the antennae, was it in the front, middle, or, rear of the coach.
EZ,
Lemon Drop, I haven't bought or installed anything yet.
