flyboy013
- Jul 24, 2020
- Mountain Aire 4531
- Spartan K3
- Cummins ISX12 (500HP)
- 2023 Jeep GC Summit Reserve
- Yes
I have a 2018 Newmar Mountain Aire on a Spartan K3 chassis. For some time (probably ever since I owned the coach) I would notice that the "Front"/Secondary air tank would have about 60-70 psi of air after a few days. I figured I had a slow leak and I've had one or two of those leaks repair at the Hadley air manifold. But I've started to notice that the air dryer would randomly purge air while parked and not running. I recently noticed it about 15 minutes after shutting down the engine but I've noticed it other times, but at the time didn't think much of it.
It would seem to me that since the air dryer purges air after the tanks are full, there shouldn't be any air pressure in the air dryer to purge at these random times. Am I understanding things correctly? So now I'm wonder if I have any issue such as air seeping back through a check valve to the air dryer? Also, it would seem that the purging of air from the dryer would require an electrical signal to initiate a purge. If that's the case it would seem that the Spartan Control Module (SCM) is directing the air dryer to purge, but again why is there air to purge if there's a check valve after the air dryer.
The purging of air hasn't been a problem, as the tanks will fill once the engine is running. I'm trying to understand what's happening and if its normal or not.
