Battery Help!
FINALLY got a break in the wind and rain. Still in low 40's, and that is cold in central Texas! Anyway, had about a hour of light left when I got home. Found the cables that go to the 2 solenoids where the converter / inverter (I am still confused on that) is. 1 cable goes to 1 side of one and the other cable goes to the other side of the other. There is a common cable joining b the 2.
Do "both" of those cables
go to the "house" batteries? Or 1 house and 1 start battery.
The cables with the "blue" and "yellow" tape are the ones I am talking about.
Next question.
The cable that runs to the generator. Does it hook to the house batteries or starting batteries.
At least I know what cable goes where now. Just have to be sure they are connected to the correct batteries and make a schematic.
THANK YOU for the help!
The relay top right is the House Disconnect relay...the Blue taped cable coming IN i from the House batteries. It is then daisy chained to the bi-directional relay...House Side. The Yellow taped cable is the Chassis Battery cable. There is a control box with inputs...that decides when to close the bidirectional relay. It does it to share the opposite banks charging system...and will close when you decide to press the BOOST switch to help Jump a weak battery.
The IOTA device you posted is a Converter. Converters take 120vac in and output 12vdc. If you have the optional device that connects to it...it makes it a smart charger, with Bulk, Absorb, Float, and Equalization phases.
An Inverter, is a device that does basically the opposite. It takes 12vdc and Inverts it into 120vac. This allows you to run household devices when off grid, and running only on Batteries/Solar. Thy come in different wave forms. Modified Sine Wave, Pure Sine Wave. The later doing better at certain motors and sensitive electronic systems.
Chuggs has it right on the cables - I can't help on the generator cabling. My buddy has a '99 Dutchstar and he didn't have an inverter either. I think he added one. I am helping another guy with a '98 Dutchstar and his has 2 750W inverters in his power bay. Seems like each Dutchstar year was built a little differently.
Anyway, you have the same BIRD configuration I was talking about, controlled by the black BIRD on the bottom left. The circuit breakers to the right are all resettable, so I would check to make sure all the "buttons" are "in" on them (check top and bottom of the CB for the buttons). Later, if you have something that quits working, remember this is another place to check. Take pics of the labels below each, they like to eventually fall off.
You got me on the Generator question. Knock on wood.. I've not come across a definitive answer...I haven't really wondered much about it until now.
Do you have a digilevel panel? The one that displays HOUSE and CHASSIS voltage, along with Tank Levels? I'm gonna try this...from my ME remote, I'm going to trigger a Generator start, while I watch those two voltages. The one that dips is starting the generator. I'm laying odds that it's the chassis...but I would be lying if I told you that without confirming it somehow.
We'll see...
Yep...chassis. The Chassis voltage dipped to 10.8v during the Generator start.
Got to spend a pretty good amount of time with the coach this weekend. Pretty sure I got the battery cable issues fixed.
I decided the generator cable goes to the starting batteries. Here's why, That cable not only feeds the generator starter, but also feeds the electrical panel for the turn signals and other things associated with the chassis. Everything works now. Alternator charges as it is supposed to. Will charge both banks of batteries. Generator will do the same when it is running by itself.
I nearly gave up looking to see which cable went to the inverter. Finally did give up as a inverter was a option on my coach. It does not have one.
For the AC's, Microwave, or frig to run (on elec), generator has to be running or plugged into shore power.
Do I really need a inverter? Maybe to have ac's or frig to run off ac while moving. Or leave generator running? Thoughts? How big of a inverter if I do add one. I saw where the new Entegra has 2 - 3000 watt inverters.
I have to replace all of the clearance light front and rear. 20 years of sunlight has turned them a brittle as potato chips.
Got all new leds on the way.
Led licenses plate lights installed also.
The power steps would not stay shut when you closed the door. They would retract and reopen in a few seconds. I figured it had to be the magnetic switch in the door, but could not find it. So I took a chance and used a magnet in a flash light and went around the door frame. BOOM! the steps closed, and stayed closed. What I thought covered a screw was the switch. The cover on the door was the magnet. I popped it out, cleaned 20 years of crap off it, sealed it on the back side with silicone, and made a small hole on the outside and put a thin layer of silicone over that hole. Less resistance for the switch to see the magnet. I am going to replace the magnet.
Newmar sent me a "build sheet" that listed a lighted entry handle. Didn't work. Took it off and the bulb socket was shot. Stole a socket off a 68 Nova parts car I have and wired it in. Now it lights up. Pretty cool!
Fixed a latch rod on the engine compartment door.
Gas gauge doesn't work..Mice chewed the wires into by the sender. I can see it, but can't get to it. I was going to cut a hole above it, but that would be in the floor of the living area.
May still do that if I replace the carpet with tile.. Newmar welded brace under the tank when they built the subfloor structure, so I can't drop the tank very easy.
Side note, if you were under the coach without the jacks deployed, or a jack failed and were under the frame, ..you would not survive. I have had 2 cars fall on me and am VERY lucky to be here today. Plenty of room in the middle of the frame rails, but I'm not very comfortable crawling in and out under the frame.
Microwave plate and racks are missing..Those things are outrageously expensive!
Have a handle for the frig coming, lock broken.
Have to fix the vent fan in kitchen that don't work.
Radio is shot, so I am going to replace it with a BOSS Elite BE10ACP touch pad. It will fit in my stock radio opening and give me the ability to more or less have my phone scene on a 10" monitor on the dash. With a adapter, I can hook up 3 or 4 cameras to it also. Put some new technology in a old bus.
Dash ac compressor is inop, so I have to figure that out.. Good thing I own a NAPA store!
Change all the filters and oil.
SOMEHOW figure out how to buy tires, and it will be road worthy and everything working.
Besides tires, and possibly kinda pricey ac parts, I really have put much in this coach.
HOPE nothing ugly pops up!
OH 1 more thing, I plan on painting the entire coach. Thinking Black with gold and burnt orange stripes.
But get all the mechanical stuff out of the way 1st.
I have bored ya'll enough, so Good night.
Awesome! Here in Florida...air conditioning would be the next big project. As far as Inverters...there has been a shift in the paradigm... My Dad's Southwind pusher has none. Fridge, furnace, water heater...Propane. TV...DC powered. About the only thing you need AC power for are rooftop air, and microwave. Then the shift toward modern AC powered entertainment systems...small inverters started popping up. And with it, need for more batteries and larger converter. Then, hey...let's use the microwave too...larger inverter, more batteries...larger converter, oh...and don't forget wiring. Then...let's run the residential refrigerator...larger interter/converter/more batteries/more wire.
The thing is...it is hard to pin down exactly what you need or want... If you do...then that's a win. Nothing worse than having a garage full of smaller inverters you've pulled out in favor of a larger one.
There is a cost benefit analysis...I admit, I love my all-electric coach. MS2812 Pure Sine wave inverter, w/built-in 125A charger. Eight golf cart batteries...more tvs than I could ever possibly watch. But then the batteries need to be maintained, replaced...eventually, perhaps a new inverter...larger wiring. Things are great...but come with additional maintenance, and complexity. Do I sound cynical? Maybe...but there isn't a day that goes by, that I'm not contemplating the next gizmo, or maintenance job. Overall...I love tinkering with this thing.
It's a 40foot Toy Box for an adult child :)
Mr. Hudson, i have the same problem on my 2000 dutchstar, coach batteries charging and engine start batteries not charging from shore power. Both Iota chargers are putting out power. Where to go from here? 907-232-5114
