Exterior Trim Delamination
bowpulpit
Monroe, GA
Ventana LE 4037
2011 Jeep Liberty
Just noticed this today.....brand new too as it was not there couple days ago. Takes some force to push this back against the sidewall so don't think tape/adhesive is strong enough. Runs from bottom of drivers mirror down about 15". Hate the thought of putting some kind of mechanical fastener to hold it flat. Anyone had this issue before or can offer suggestions on how to repair it?
TIA
Unfortunately not uncommon. @TJ&LadyDi had this on his Ventana LE. I suggest contacting Newmar, it may be under the structural warranty and they'll arrange the repair.
Thank Neal....was not aware that I had warranties of any kind left since it's a 2016 and I'm the second owner. I leave in 10 days to winter in AZ so will probably put some tape over the gap to prevent water intrusion till we get out there. I know NIRVC has a dealership in the Phoenix area and maybe thats where Newmar will direct me.
Yes, as @Neal posted, we had that same problem a few years back on our 2014 Ventana LE. Newmar stepped up and covered it without any hassle. Our coach was repaired at Guaranty RV in Juncion City, Oregon, using both mechanical fasteners (screws) and adhesive. When the job was done, it was impossible to see where it had occurred.
Take a couple of photos clearly showing the separation and location on the coach, Then, call Newmar and explain that you have a "sidewall separation," and that you have photos you can e-mail them. We did that and in less than a day, were told that Newmar would fi it under warranty. I'm confident they will do the same for you.
EDIT: We used 2" Gorilla Tape to cover the opening and it worked fine until we got to the repair facility.
Desert Autoplex in Mesa is the designated Newmar dealer in the Phoenix area. You DON'T want to go there. If you want NIRVC the one in Vegas is the closest Newmar dealer. Or I can recommend Freedom RV in Tucson. We had warranty work done there.
There are ways to have that fixed without screws using epoxy (there are YouTube videos on how it’s done), but follow the others suggestion first and contact the manufacturer.
True, but the folks that fixed our coach delamination problem were of the opinion that using just adhesive (which includes epoxy) at critical stress points is just asking for trouble. The body shop foreman told me "we fixed it the way it should have been done in the first place." He's had more experience with that than I have, so I took his word for it. ;)
TF
Thanks...I think NIRVC recently opened a dealership in Surprise AZ.....close to Phoenix
Surprise!!! Spent some time in Youngtown building a handyman business there. long time ago.
They have been open for several years in the Phoenix area and yes they recently moved into a new facility in Suprise. However, since Desert Autoplex is the area Newmar dealer they don't do warranty work. I have used them for non warranty work and they are excellent to work with.
the epoxy is just to adhere the fiberglass exterior to the in many cases the thin plywood backing. It is not intended to withstand any real stress.. usually delimitation occurs in the backing material due to water damage or something like that. If the epoxy is put on correctly and no damage to the back material and you had excessive stress you would see cracks instead of delimitation. I’ve had those to in the past at the corners of a slide out on a 5th wheel. There was a week spot in the design of the wall structure. In that case I designed a metal plate that I put on after repairing the crack. using countersunk screws, the fiberglass bonds, painting it looked just like the trailer was made that way and never had a problem.
I can agree that the thin plywood is what is de-laminating. On my Adventurer I needed an access port to repair something so I cut out the delamination to accomplish the job, and put a door in it's place.
Before I chose to do that I concocted a scheme to repair the bubble I had. However unsure how the foam would react to the epoxy I kept putting it off. My plan was to use vacuum to suck epoxy into the bubbled area and my thoughts were the foam might just melt so didn't do it.
