- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
Yes I have, take the soft side of Velcro and cut 4 5 inch strips, bring your shades down to driving position and center the 4 strips in the front and back side of the shades within the tract.
Yes so it faces the shades on both sides, felt would also work.Are you placing the strip inside the track?
If you’re not using the shade while you were driving I have seen that most people simply wrote a bungee strap around it. That seems to hold it tight. Sometimes you can add additional mounting brackets to support the head rail. Finally if there is an adjustment on the upper and lower limit settings you can adjust the upper limit to where the rail is all the way to the top and snug against the head rail. That should keep it from moving as well. Please feel free to contact me if you have any other window covering issues or needs.I'm not sure if it's just too flexible of a rod holding the front window mesh shade or what but at times it rattles quite a bit. I know to lower it slightly and that usually helps but has anyone taken measures to fix that rattling of the shade?
