Problem 1995 Fleetwood no start/power
I have only 2 heavy battery cables coming from the battery. Wire to power fuse box is a heavy gauge but not even close to battery cable size
Yah! about a 10AWG. that goes to the fuse block or alt. the other goes to the starter circuit.
most likely the 10 is split someplace or to a terminal post/fuse.
That wire should have something like a fusible link right where it hooks to power. IF it does, see if the wire stretches. Stretch = bad, no stretch = good.
Here is a discussion on another form. Many of the questions revolve around safety switches, particularly the Neutral safety switch.
Some Ford wiring info
