TXfreeze
- Jan 6, 2021
- Holiday Rambler
- Endeavor
- Roadmaster
- 350 Cummins
- None
- Yes
The engine cooling heat transfer feature on this water heater works, the switch works, I can see sparks when the switch is turned on, it just won't ignite, I checked the tube for obstructions there are none and no nests in the the exhausts, the propane tank valve is open to full, checked burners and flow is fine, is there a valve on the water heater itself that could be closed, if not what would be causing this?
