Joe Dutchstar
- Nov 3, 2019
- Florida
- Dutch Star 4311
- Spartan
- Cummins
- 2018 Ford Flex
If you have noticed that a trucker only uses the clutch on initial shifts from a stop. There is good reasons for this and the clutch is specifically designed to work this way.
The clutch has a brake, when the clutch pedal is depressed a friction brake is applied to reduce/eliminate transmission idler shaft revolutions. This avoids gear wear (grinding) going into initial shift into forward or reverse from a stop.
Just an interesting thought of the morning..
truckerslogic.com
What Is A Clutch Brake? - Truckers Logic
The clutch brake has a circular disc with a friction surface that connects to the input shaft of the transmission between the release bearing and
