- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
@ARD is having her 3rd installed as we speak and sure enough I think mine is on its way out. The furnace fan (convector?) that is under the dash front and center of the coach. It's on high but it's cycling as if either the power is unstable (others are not cycling) or the convector is on its last leg. In talking with @ARD it seems like there may be a bad batch of these fans out there, not that I expect Newmar to replace this one well outside of warranty, but I'll certainly inquire.
Anyone else have one fail and did you replace it yourself? I've removed the one when fixing my shower drain but didn't disconnect anything, I'm thinking just have to clamp off the two lines and then get the hoses off. I tried disconnecting the fan when doing the shower drain replacement and those lines felt glued on and were not coming off easy.
Any tips welcome on these heater fans.
