Question OASIS Hydronic heating underperforming with electric elements?
I'm curious if something is not working as designed in my ITR OASIS hyrdonic heating system when using AC I/II (both electric elements). It's summertime and not using OASIS for anything but hot water. I shaved then showered. During the shower the system can't maintain the hot water. I would expect in summertime and hot water use only I could get through a shower with sufficient heat from both electric heat elements. I did the voltage test and verified both AC I and II are showing the approximate 12A draw. Diesel burner heats as expected when used.
For those with OASIS units, can you get through a complete shower with sufficient hot water? Any ideas what may be wrong with my OASIS electric burners? I do have a heat 2 loop pump failed but don't think that's involved. Reservoir has correct fluid in it so that's not the issue. Coach is now 4 years old (today!!) and I'm getting the fluid flushed at Newmar during my September service.
Ideas??
We find the electric elements “sufficient” for a shower, though it depends on how HOT you want the water, the duration of your shower and how much water you use. We’ve installed a quarter-turn ball valve at the base of the shower wand that allows us to cut the flow in half (+/-) and that really helps. That said, we frequently turn on the burner during “shower time.”
It has to do with input temp of water. In Montana, the water is much colder than texas water. Takes more BTU to heat it.
Our electric elements (both on) provide very hot endless water (even when it's been in the 50s in KY recently). Can't add why your's doesn't provide enough.
I asked @ARD and @NWIP who are here and same issue, it IS the Montana ground water temp as @redbaron stated as well. Confidence isn't fully there with the OASIS with the history of electrical issues in shorts and relays. I use the burner often as I enjoy the continuous really hot water as needed.
I'm having the same problems with mine. Both elements are drawing correct amperage, but it has been getting worse as time goes on. It seems that something other than input water temp that is causing the issue. Just parked after a brutal day driving in Michegan. I will check input water temp tomorrow . Any other ideas? We used to be able to take two showers on electric. No more. 2019 DSDP 4369.
Let me know what you find out. Maybe give ITR a call. My coach is in storage until September.
Just finished a trip, same issue. One element used to work during the Summer. Now we need both and for the first time during the Summer I had to fire up the boiler. Something is up.
I had the problem. It was bad wiring connections that overheated and melted. The wire bundle is on the left side when facing the Oasis panel with the green lights.
Your problem could be different?
Neal, I haved a down time tomorrow as we transition to Oho from northern Michigan. I will give ITR a call and see what they think.
Huh. You guys get decent hot water on electric? I never ever have. We always use the burner because without it, we only get luke warm water at best, even in AZ and Texas in the summer.
wish I’d not read this. I was perfectly content with my ignorance.
John,
We are in Michigan, and we use only electric. It is enough for two people.
You may have only one heating element working? Check if your amperage consumption goes up when you switch from One to two elements..
It was off. Haha. We’ll see if that makes it better
ITR was of no help. Only advice was to wait till tank reaches temperature, or to use the diesel heat. That doesn't work when we have guests at home and coach is in the garage. Duh.
When I go to Newmar in September I'm having the heater fluid purged and replaced which I'm guessing is something most are not doing but it is in the service schedule. I'll let you all know if this alone improves the situation. I'm guessing if the coolant system is not performing as it should you're not going to have proper heat transfer. The only other suspect is the electric burners have a lifetime and need to be replaced.
