- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I'm curious if something is not working as designed in my ITR OASIS hyrdonic heating system when using AC I/II (both electric elements). It's summertime and not using OASIS for anything but hot water. I shaved then showered. During the shower the system can't maintain the hot water. I would expect in summertime and hot water use only I could get through a shower with sufficient heat from both electric heat elements. I did the voltage test and verified both AC I and II are showing the approximate 12A draw. Diesel burner heats as expected when used.
For those with OASIS units, can you get through a complete shower with sufficient hot water? Any ideas what may be wrong with my OASIS electric burners? I do have a heat 2 loop pump failed but don't think that's involved. Reservoir has correct fluid in it so that's not the issue. Coach is now 4 years old (today!!) and I'm getting the fluid flushed at Newmar during my September service.
Ideas??
Ideas??
