Ordered 2020 Rubicon Today - Tow Baseplate Setup
Gizmo
Kansas
Ventana LE
2020 Jeep Rubicon
We put a Blue Ox baseplate on our 2017 Sahara but thinking about put Roadmaster on the Rubicon. I think little cleaner installs and few bucks less for the baseplate. Here a pic of an install that I found on youtube. You can see there no crossbar showing which makes clean and doesn't affect the approach angle.
Whatever tow bar you get make sure it is long enough to accommodate the wheel cut angle of the coach. This is a big deal with the 60 degree wheel cut in the New Aire. See this post.
I have a Ventana LE so that shouldn't be a problem. I have the BlueOX Avail 10,000 pound bar and had to by new clevis to hook it to the Roadmaster baseplate.
Probably a good idea for everyone to find a big parking lot and may a slow tight 360 turn with the TOAD attached just to make sure.
The roadmaster nighthawk is a great towbar and it lights up at night (coach lights on) making it easier to unhook. I have the baseplate as well. I bought an extra set of brackets and had a buddy of mine weld the front tow hooks on.
The concern I have with Roadmaster is there no bar between the left and right tow bar hookups. Seems to me there would be an outboard and inboard stress generated on the frame connections that would cause those connections to flex the frame. I have zero engineering experience just trying to use common sense. The only reason I even brought this up was a friend had a Jeep Cherokee that had the same type of connection and found frame cracks after about 20,000 miles towing. It was a BlueOx tow bar the BlueOx solutions was replacing the tow bar with one with the bar between the left and right connections.
Here is what I’m going with, their bumpers are mounted with 4 bolts on each side that sandwich the bumper to the factory frame bumper holes. The tow brackets use 2 of the 4 bumper bolt holes and can be installed in the top or bottom holes. The pull will be directly to the frame not a pull from a lever 6 to 8 inches below. Don’t get me wrong, the blue ox set up on my 2017 JK worked great. I just didn’t want it hanging down below the bumper for off road driving this time.
The link says 2007- to 2015 but it’s the same mounting
I should also point out that the aluminum version I went with is 1/4 thick and weighs under 40 pounds (looks the same as bumper in pictured in link)
Roadmaster Nighthawk Towbar here. Love it. Zero issues so far.
If I was in the market for a new towbar I agree. Lights are cool but the cable management is impressive. I have a BlueOx Avail and works.
On my 2015 Cherokee Trailhawk, I had to have a mopar kit installed to prevent the so called “death wobble”. I think I read somewhere that issue was fixed in 2018 going forward and not sure if it pertains to all Jeep lines or just the Cherokee lines. Anyone know? The kit was not a cheap install. I’d like to get a newer Jeep and would like to not have to do the install again.
The Wrangler line doesn't have the wobble while towing as the Cherokee does. There is a problem with aftermarket tires, mods, etc that causes a wobble while driving. I also own a 2017 GRAND Cherokee that does have the wobble but so far reports are that happens in a left turn and under 10 miles per hour. There IS NOT a harness to fix the problem on the Grand Cherokee like the Cherokee.
Maximus-3 front tow hooks are another great option. They work with a Blue-Ox connection, which you can adapt any of the road master to.
I have the RoadMaster AllTerrain BlackHawk2 tow bar, and just swapped out the knuckles.
The Maximus solution is nice in the fact that the connection doubles as a recovery point or jack location. It does require cutting the bumper, but that was simple. I did it myself in about an hour.
I don’t know about the 2018 but I can say for the 2019 Cherokee, no mopar wiring harness is needed. Jeep TSB08-040-18 revision B.
You will need a wiring harness for the 2018+ to connect the RV to the Wrangler for brake lights, turn signals, and marker lights.
I went with cooltech's wiring harness, very simple.
As far as the Death Wobble (DW), this is something that has been addressed thru multiple recall campaigns. There are 4 revisions of the steering box, and 2 recalls on welds.
If you have a 2018, you will have to get multiple recall campaings completed.
2019 has 3 or 4 open campaigns.
2020's manufactured before July of 2019 has 1 or 2 campaigns. After Aug 1, the line implemented all known campaigns, and there have not been any new ones.
The welds are the single largest issue affecting 2018-2019. The gear box is the second. Looking at the gearbox revision is the best way to know if you need to have a recall done.
DO NOT accept a steering damper as the sole fix, this has already been proven to be a bandaid to mask the problem. The steering gear box is the only true fix. There is no need for a damper with the corrected gear box.
What is Death Wobble?
This was true for me. I had to purchase a special wiring harness. Luckily they had it in stock where I had my towbar and AF1 installed.
Order Yesterday and my status is "D - firm schedule: serial number assigned, approx time in station - 5 days" and also got my VIN number. That was less than 24 hours.
I placed my order on 10/4/19. I was JB status on 10/16/2019. I remained in JB until 12/6/2019 when it finally went to KZ. Then it got "lost" again, and finally delivered to the dealer on 12/27/2019
What I learned is:
#1 - In october, the factory dual option tops where causing a delay. The Mopar accessory items where delayed. This accounts for 6 weeks of time.
Then the rail transfer taking 3 weeks is explained by the holidays.
The final frustration is when it delivered to the rail port @ Alliant (40 miles from my house, 30 from my dealer), it remained there for 8 days due to holiday and back log.
Water under the bridge now,but sure was frustrating when at first it appeared to be available by Thanksgiving.
For all those that have FL chassis, has anyone priced using discount offered thru FL Owners Club?
I used that discount as well, but it is not the best deal.
Dealer holdback on a rubicon is around 1750.00
Invoice is approx 1400 below retail.
There are other incentives and stacking that can be done, with the average deal being 6% below dealer invoice.
