- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I don't recommend it! For those following the DEF head(er) crisis you may think you should carry a spare DEF head(er). As I recently discussed with someone else, I don't think it's a good idea. If you're in a location where one can be installed, then you're likely in a location where one can be shipped and apparently it's required to be installed by a Cummins certified tech. But the real reason is that vendor(s) continue to try to figure out the sensor and have been coming out with new releases to try and solve the ongoing issues which seems to have been going on for around 4-5 years. So if you spend the $1K+ to buy a spare DEF head(er) (latest I hear is $1325) and it's GEN X for example, and in a year or two you have your DEF head(er) go out, do you want to use your GEN X which is "known bad" (obsolete) and I'm sure you'd rather have the latest installed at the time of the incident. Think hard before ordering a spare DEF head(er) when you can get one due to supply issues. I think it's a bad idea. My $.02.
