How to shut down solar panels
Louisfarm
I have 6 100 w solar panels. Im not going to use the rig for a few month and would like to shut done all power to the rig. I'm thinking on shutting of the batteries and pulling off negative lead, disconnect a/c shore and inverter. Also, i was thinking to disconnect the solar panels by disconnecting the input wires from panels to controller. Am i think straight or an i developing a hazard and possible equipment problems? Please advise the right way of doing or modification to my direction
The panels need to be turned off before the battery connection to the controller.
You should have a disconnect between the panel and the controller.
Yes, i do agree and it wasn't done at installation. I've looked for one on internet and only saw battery disconnects and none for solar. Can you please send me info as to buying one?
The switches are double poll motor switches available at homedepot. Good for 115v 10a. I doubt your panels voltage is over 115v, or more than 10amps.
The ONLY things that would need to be disconnected are your batteries and the solar panels, that’s it. If you disconnect everything else then you risk hooking something back up wrong and also risk stripping terminals out or not making them tight enough. Both of which can end up being a fire hazard.
Turn solar panels off and disconnect batteries only and you will be fine.
Bringing this one back up.... Dumb question.
I have a disconnect between my panels and controller... But do the panels mind being in the sun with no where to send their power?
I'd imagine if the wires are disconnected it doesn't matter. Does current flow if there is no circuit? A battery has two terminals, it has juice but without a circuit there is no flow of current. Dr. @Chuggs told me disconnect panels to charge controller prior to powering down charge controller. Panels first then battery disconnect. Reverse when powering back on.
Ok. That makes sense. Just something I was thinking through.
Thanks!
Rich
Every time your charge controller gets PV voltage sent to it…it wants to perform it’s calculations…but with no place to go…it will just drop and die…then awake again…and you’ll get a pinball effect. I saw a YouTube video where an off grid couple had solar panels connected to a charge controller with no battery…the display on the charge controller totally went crazy. If the charge controller is first connected to the batteries…then it’s processor will have something to power it, and can derive a purpose based on the voltage…then the PV appears, and the controller knows what to do with it. So, I always recommend turning on the brain before the brawn…and disconnect the brawn before the brain. The panel itself is almost like a self contained battery, with variable output based on sunlight intensity. If you disconnect it…it will merely be like taking a AA batteries out of a flashlight. As long as light shines on it…it has potential…but does nothing with it until connected to something. Of course, this is unless you have panels with built-in controllers or micro inverters. I would read the literature for those to see if they can be damaged sitting alone unconnected in sunlight…. I haven’t toyed with any of those yet.
Thanks Charlie! That helps me understand better.
Rich
