MOD LED lighting with Boogey Lights on a 2017 Newmar Ventana Motorhome
People at the campground don't complain?
They aren't strob lights just a Christmas light. Second I don't do campgrounds as a rule. I have been asked what they were for and I tell them mouse control. Thats the end of discussion.
We just got back from a run up to Boogey Lights for an install on our coach. Great folks to work with. We did the full under glow/ engine compartment/ wheel wells/ and replaced factory light on Pass slides.
We also had the put lights in the panty
We used two zone controllers on the under glow and slides and can get some great effects.
Sort of a community " joke" in our MC resort to light up the night; at least till bedtime. ;)
Wife is already trying to find additional places to add lighting.......
Mighty big lowrider. Have you figured out how to make it rock?
the guys at Boogey had it flashing like an emergency vehicle, looked great (especially in the dark shop). we use them when at our home lot, and sparingly when on the road. If we are sitting out, it is before quiet time, and we aren't going to intrude on others; i will put on some underglow. We kill it before it gets too late. We apply the same policy to the accent lights (C lights) on the coach. We like how it looks, but understand others may not be that enthusiastic.
I recently had an Allegro Bus park next to me with underglow lights under the slides. I think he left them on all night. I thought they were cool. I would love to get some. If you park next to me leave the lights on. It also makes it easier to get back to my coach on the occassion that I venture out in the dark. :cool:
Haha, I do use them to "find" my coach at times. I also use underglow at times when parked in front of my house to make my coach more visible to traffic.
A bouncing DP. Now that would be intriguing.
Bouncing?? Wasn't thinking about that. I was thinking more along the lines of that old sign from the trailer trash days. "If it's rocking don't come knocking "
Lowrider bouncing the front. Can you imagine?
Sounds like a greenscreen event.
If we park next to you, we will hook you up. Even let you pick the color scheme:)
I installed the under glow boogie lights on my DP several years ago.. easy install and still going strong!! Love em!!
What did you use for power? Where did you run the power wire?
I have an compartment that has peg board setup with an outlet so controller and all else went into compartment. I drilled a hole through bottom of compartment to bring in wire off of lights. Was really easy!
This has been on my bucket list for years. I even saw Neals install when we were both at the balloon fiesta in 2019…. Someday!
My wife love the boogy lights in the panty😁
As I reviewed the images above I forgot to mention how I secured the wires coming down the sides of the slides. Originally as Newmar uses wire loom for everything I decided to run the wires down a wire loom and then use Sikaflex 221 (like silicone) to secure it to the inside edge of the slide. It does not interfere with the slide seal. When I did the full wall slide I decided NOT to use split loom but instead just use black gorilla tape to hold the wire in place. This worked much better and it's more of a low profile setup. I have had some of the split loom come loose and used black gorilla tape over top of it. I imagine it's struggling more with the slide seals and the seals pulling on the loom.
Sika flex is awesome product!! The 3M they use for the boogy lights is impressive!! Living in fresno where the Temps reach 105 up to 115 i thought i might have a problem with the 16' strips falling off but still stuck!! Is it illegal to go down the highway with them on??
