J&JD
- Nov 3, 2019
- Fremont, California
- Dutch Star 4018
- 40’
- Freightliner
- Cummins ISL450
- Jeep Wrangler Sahara
There have been several threads on different rv forums discussing the importance of running the engine while operating the slides to give you optimum voltage for the slide motors. This made sense to me so I decide to use this procedure when operating my slides. Well……Newmar has some weird stuff going on with my coach and I would like to hear how other’s slides work.
1. The HWH full wall slide will work in or out with the engine running or the ignition off, doesn’t matter. It does seem to work best with the engine running.
2. The kitchen slide will come in with the engine running but will not go out with the ignition on and/or engine running?? Go figure.
3. The bedroom slide will not go in or out with the ignition on or engine running.
Why would the slides be wired completely differently? Obviously running the engine while operating the slides will only work for the FWS on my coach. How are your slides set to work in relation to the ignition?
