Propane usage
Russellvh
Forest River
Wildcat Fifth-wheel
2019 Ford F-250.
2022 FR Wildcat 5th wheel.
Only camping used in the past with multiple propane tanks was in pop up. I used one tank until it stopped then closed valve and opened valve on other can. Then filled empty tank within next couple of days.
New trailer has two tanks. On one tank there is a gauge showing red and green. Plus a lever on top. From what I understood, I am supposed to open both tanks. Then I check the gauge each day or so. When needed the tanks will automatically switch and the gauge will turn red. Then I rotate the lever and refil the previously used tank.
Have I got this right or all confused?
Sounds right.
If you ever get trapped in a cold climate for 2 winters on a job like I did once I'd suggest buying extension hoses and sitting those propane puppies on the ground. I had 4-30 pounds and 2-20 pounders in front of my fifth wheel locked together with a cable.
Lifting that tank out, going and getting propane, and putting it back in isn't something you want to do every other day when it's 5 degrees outside.
Although we have two 40lb tanks and the automatic change over, I learned my lesson. I woke up cold one morning only to discover both tanks were empty. Since then I only turn on 1 tank at a time. When it is empty, I remove it and turn on the other tank. Never again without propane. The wife will never let me hear the end of it.
Same here. It might be inconvenient to wake up one morning at 2 AM to switch over to the full tank, but it's a lot better than not having any propane at all at 2 AM.
Maybe my valve was different than what you have but it told me when one was empty.
It would switch over automatically and show red so I knew the other tank was empty, so I'd take the empty one out and fill it. Never have I ever ran out of propane in the middle of the night.
Sometimes you get lazy about checking the switch, which is what happened to me. Propane always seems to run out between 1 AM and 3 AM. :giggle:
You said yours"told you" when one was empty. Mine is under the tank cover and is not readily available, nor visable. Also, mine doesn't talk or have an internal annunciator as yours apparently does.
Red means bad, green means good...
When I know I've been using some propane I'll go out and check the weight of each bottle every once and awhile. When one start getting pretty light I'll take it out and go get it filled. No fun running out.
I'm really happy not to have to mess with propane much now that I have this diesel pusher. Heat pumps in the roof (my fifth wheel did have them also) and diesel hydro hot for heat and hot water.
Still have a large onboard propane tank but it's just used for the outside grill, inside stove burners and the refrigerator can work off of it but hardly ever does. I filled it up before we left for Florida last fall and it's still showing almost full.
I do miss some of the features of my all-electric Newmar coach. Not having propane was one of the nice features. However, as diesel prices go through the roof I'm certainly glad I switched back to a fiver now. Getting 9.5mpg is easier to take than 6.5mpg, plus it is easier to shop around for the lowest price.
