Resolved OASIS Electric elements not working?
2017 Newmar Ventana with OASIS hydronic heating system. I may be jumping the gun but I ran the water in the kitchen sink and had no hot water. I looked up and saw that the green light was not on next to AC I/II with the switch set to AC II. I went out to the bay and the power was on and no red lights. I came in and turned on the burner and now I have hot water but still nothing on the AC heating. I'm hesitant to cycle anything as I do have hot water and don't want to lose that.
Breakers for AC I and II both are ON but I did not reset them.
Any ideas why AC II is not coming on?
Could this be related to the work you recently had done? Could the service guys have turned off the AC1/AC2 breaker because they didn't know how else to turn the system off while the coach was in the shop? Otherwise, despite your reluctance to do so, I'm thinking a full reset (salesman switch) is probably in order. Or, maybe a phone call to ITR?
No, I don't think it's related to the Cummins work and I haven't had an issue since returning last Friday until now. This morning I did a salesman switch cycle twice for the aisle lights dilemma, not sure if that caused an issue. I just killed power at the pedestal and waited 10 seconds and brought shore power back online, no change. I cycled the two OASIS breakers, no change. I pulled the two 12V fuses related to OASIS after powering down OASIS, no change. I've been through the service manual and it's not helping much. I may need to check the 2 x 120V connections again that had shorted 1-2 years ago we all talked about at that time and see if something came loose but I'll likely have to call ITR before going further and see what they suggest before messing anything up.
Our systems work differently; SilverLeaf controls the Oasis in our coach, so I'm not familiar with the switches you referred to. They probably function the same, but ours is hidden (probably relays vs switches). Actually, your switches probably control relays somewhere to feed power to AC1/AC2. Do you know if they are plug-in relays that may have failed?
Good morning Neal,
I had the same problem with my Oasis. It turned out that it was another bright idea of some electrical professional. They hooked up high load 3 way connection using spade connectors.
Eventually overheated and melted the spiral wrap insulation etc. Lucky I did not have fire.
The offending part is on the left side when facing the control panel. You have to remove the next shroud which is about 4" (no big deal)
One other option is that the AC relay could have gone bad. It is in the same area.
Thanks Buly and I had that too about 2 years ago. This afternoon I’m going to check the 120V connections again.
Many thanks to Kevin and Randy at ITR Heat for their outstanding and extensive help today in troubleshooting this issue. This was yes ANOTHER short but this one further down under the hour meter. Most likely this short was an extension of the prior but remained intact until now over a year later. If you want to inspect your wires as this OASIS setup seems to be quite the hazard you can pull the hour meter and also the front face plate of the OASIS system and inspect with a flashlight carefully.
It also appears since the last short I likely, if ever, had both AC I/II heating elements working. I'll create a new post on how to test your OASIS so you know both AC I and AC II are in fact working for you. I never really thought that much of the electric elements such as for showering and this is why, new post coming on that.
So I'm all set, no new parts needed, just a lot of wiring verification and do overs and fixing the short AGAIN but in a different area.
This is really concerning we are driving around with known hazards in our coaches. I am not an electrician and now I am going to find someone or someplace that is going to do a full inspection of my oasis because I want to know that there is no known fire hazard in my coach. It’s ridiculous we should even have to do this. I am preaching to the choir I know. I’ll shut up here.
No breakers ever tripped but I think that's because it was a clean break and possibly that the AC relay is connected in so with the break in the relay it essentially never called for power. Yes, the OASIS wiring is a big concern for all, the first situation threw large sparks hence driving me to install smoke detectors in the basement. While these things are unfortunate something good always comes from it.
After my experience with Oasis, I also installed 3 wireless, interconnected Kidde smoke detectors. One in the basement between the Electrical bay and Oasis, One inside the coach, and when at FL home for the winter, the 3rd sits on my desk. If the coach starts smoking in the garage, I will be alerted (I hope).
Bought my smoke detectors pack of 3 at Home Depot on sale for about $80.
My challenge is finding smoke detectors that I can see and hear that don’t require hard wiring. There are options but they don’t all work well.
Yikes! I guess I need to do the full inspection--again! Our coach had the new-style connections in the main Oasis wiring, so now I need to verify the hour-meter connection. This is crazy!
Well this is interesting to say the least. About 6 weeks ago while sipping an adult beverage I thought I smelled the magic smoke smell we all really hate. Looked under the cabinets, behind closed doors and the storage bins. When I went outside I could smell a really stinky fire in the state park we parking in so after looking in the bins I thought that’s got to be it.
I went back in and since I was working on the adult beverage, I promptly forgot about it.
Fast forward a month and I noticed that while AC I/II was one it was only drawing 12 amps. Turned it to AC I and only 12 amps on L1 then AC I/II still only 12 amps On L1 with no change to L2.
I looked at the manual on trouble shooting the Oasis and read that there were 2-20 amp circuit breakers in the AC panel in the half bath. Lo and behold ACII’s CB was tripped. Reset it and it held, went out turned on AC I/II and 12 amp L1- 12 amp L2. Checked the breaker again and it was holding.
So by this time your all thinking wow he’s got a short. And with me having worked with electricity my whole professional life so should I but no! Remember the adult beverages ??!
A few minutes later the DW comes out of the shower and says LOUDLY, WHAT’S THAT SMELL!! Ding, Ding, Ding the light bulb goes on. I jump up, run to the electrical cabinet and shut off the still not tripped AC II Breaker and call our friend Randy at ITR.
While Randy told me what to do, I haven’t done it yet. Just left breaker 2 off and have been using only AC 1 until I can get to a cleaner location to dig in.
Hopefully next week.
Thanks again for this info as it really drives home the point when you smell the magic smoke, find its source!!
John
John
Yes that magic smoke is should be taken as a warning sign, glad the breaker did it’s job. Early in my aviation career I was asked what are circuit breakers for? Point he was making was they are to prevent fires.That has stayed with me and if a breaker is trip I want a explanation prior to resetting. Easier to just reset and see if it trips again but that may be to late.
Hopefully your damage is not to extensive.
