Need to change out frig
mchlquick
I own a 2008 Monaco Diplomat 40SKQ. The frig is a Dometic NDA1402. The water drain heating element is once again burnt out. It appears that they are no longer available and I need to change out the frig. I want to go back with a standard household unit. Anyone done one??? Need help!! Have 26" door opening to squeeze something thru
I have a 2006 Holiday Rambler Ambassador PDQ floorplan made by Monaco. I'm sure mine is very similar to yours. I priced a Norcold fridge after mine went out and decided no way I was spending $3600 for another. I wound up buying a Samsung 18F stainless steel residential fridge with bottom freezer and put it into my coach. It fits like it was made for it. I had to take the doors off the fridge to get it up the steps and I had to take the passenger seat out but it wasn't that bad. I did a big write up and posted pics in the Interior RV Updates section. Search for my posts or look in that section and you'll see what I did. Let me know if I can answer any questions for you.
Here's my post.............
Thanks EZ. My frig is located over a roller on the slide and my furnace is under the sink. The Samsung is too tall but I think I can fit a Frigidaire in the hole. Going to Lowe's today to take measurements. Thanks for the info
Please let us know what you find that fits. My 1402 is in the slide also so EZ's fridge would be too tall.
My 1402 is running fine but I like to plan ahead.
My fridge was right over top of my furnace so I made a sheet metal pan for the fridge to sit in. The Samsung fit the hole like it was made for it. Very little trim work was needed.
If I didn't have the furnace sitting right under my fridge I could drop it down a foot or so. It might fit inside the slide then. Measure twice and cut once though, right? Lots of choices out there. Let me know if I can help.
I don't have a furnace there but I do have a drawer under the refrigerator that I'm in love with.
Update: I believe that my 1402 is OK. It seems that the freezer door was left ajar and that caused the ice build-up in the drain tray. The defrost heater strip is good. Lucky me, but my research found that a Frigidaire 17.6 cu-ft counter depth French door refrigerator w/ice maker and bottom pull out freezer will fit. The floor will have to be lowered to the top of the roller adjustment screw but it will fit. My new question is, how to get the 1402 out of the rig. Cut it up into pieces or does the generator unit come off and make it small enough to get thru the door. Don't like ammonia. I may have to still replace the frig in the future
My 10 cubic foot Norcold 4 door fridge came out the front door. (sorry I don't knop the model number) The new Samsung residential came in the same way after removing the doors on the fridge and removing the passenger seat. I had a whole 1/4" to spare! You'll need two people. It's heavy.
Hello sir I am going through the same process now with my 2005 ambassador. Same samsung replacement. How much clearance do you have above the heating duct work etc which is below the fridge? Its fine depth and width but height is a real close one. Did you remove the adjusters and rollers?
Thanks
Just a suggestion, measure the refrigerator it self,not by what the specs say,I say that because someone I know purchased a new one ,and found there was a 1/4 inch strip on top for a power line or something. It won't slide into the custom cabinet the old one was made for.
I wonder are RV appliances built stronger to compensate for the constant moving, maybe more so in trailers?
Or are they more expensive because of the ability to run on gas?
I did it on my coachman Encore. The fridge went in through kitchen window by the table. We set it in the truck and my daughter and I put it in. We took the doors and hinge points off and all the shelves and drawers out See photos. In preparation we took the Kitchen window and frame completely out. Many more photos of the project if needed. Side note. The original fridge shown was 12.5 cubic foot. I bought a 23.5 cubic foot Kenmore Elite with in door water and ice. It was a scratch and dent and steeply discounted. It had a small door dent.
I Have my own opinion on that! No! they are more complex! What is built into a residential fridge are the same components that are in a window ac or rv ac, and like those two items, because they are basically one box are inherently reliable. Some argue economy of scale, however little change is made year over year, so tooling investment is low for the RV fridge. The RV fridge simply has two heat sources! Propane burner and related equipment, and a big resistor, with related and shared equipment. NO! Is because, in my opinion, they charge more simply because they can! I have been replacing my fridges with residential units for I think, now it's been 18 years! You need side clearance because they are designed for free standing applications, but the cabinet has the side clearance needed.
I vent the top of the cabinet for natural convection!
