Question p/s electrical outlets not working on a 37pa RED
I’m not in a Tiffin, but I would first look in the breaker box for a tripped breaker. On mine, it would be labeled “pass side s/o”.
Failing that, look for a tripped GFCI.
Thanks, those were my first 2 places to check. All breakers are closed and no GFI tripped. Any additional ideas?
Had this happen and it turned out to be inverter. Had to do a reset. This was on my American Tradition (Xantrex inverter)
Appreciate any help
Hi Terry: Ok so you checked the main breakers underneath your Spyder control panel, then the push button breakers located on D/S first bay. Are you just parked, using generator, or shore power?
You can also do a reset of the inverter, it has a red button reset switch right on front of panel, or and hitting the main power switch, on & off on P/S lower bay.
The main power outlets near the sink will not work unless you are running generator or hooked up to shore power. I use those for coffee pot & toaster oven.
Let me know how you make out.
HH
Had another brain fart. Check the GFCI electrical wall outlet in bedroom or the closet, hit reset if inoperative.
