Power Station Plugged into your RV AC Outlet
Thor Compass
Question: What if you purchase a 2000W 2131Wh Lithium Ion Power Station. Then used an Extension Cord that has male plugs on both ends to plug it into your RV Wall Outlet. Of course you would not be hooked up to shore power or have your generator running. Of course, you would need to remember to unplug it when you do use shore power or your generator. However, would this safely power all your RV AC wall outlets and appliances? Thanks in advance for any replies.
Respectfully, Extension cords with male plugs on both ends are considered “widow makers”.
I agree with FloridaSon....There are better ways to do this... Like plugging it into the shore power plug via a dog bone adapter. Maybe you could store it in the basement?
Why would you want to use a male to male cord?
Meaning, the this would cause a short circuit, or the cord itself would start a fire? Just narrowing down on how to correct this setup by using a heftier cord or not do this at all. Thank you.
My vote is for "Not at all".... It is so non-standard and pretty dangerous... Having a live male plug just seems like asking for trouble...
This goes by another name - "back feeding". Definitely NOT recommended. Its the wire in the wall that you can't upgrade to a heavier gauge that would be most worrisome here.
Rick
The RV already has two 12-volt wet cell batteries, however, they only power the lights, and water pump, nothing else. I'm trying to avoid doing a more complicated inverter and switch setup. Shore power will power everything and charge the wet cell batteries. Trying to avoid charging the house batteries with the power station. Thank you.
Plug the power station into the shore power plug and turn off the battery charger...
That sounds better. Do you have an idea of the wiring to install a switch to disconnect the power going to the RV charger? I would also need to put the powers station that is protected from the environment, and the thick shore power cable and the AC-Outlet adapter that plugs into the power station. Thank you.
Not knowing what kind of RV you have and how its laid out, it is hard for me to say how to do it. Nor am I really sure that turning off your charger (converter) is a good idea either as it helps your rv 12v system work.
But if you plug in your power station and your batteries are charged, the charger should not take much power from your powerstation.
As far as protection, not sure how big your powerstation is. Maybe you can use a compartment? Or cover it with a tarp or tent?
Thanks, Rich,
At least you got my wheels turning thinking about it in a better light. If you are an above average RV electrical guy, maybe you can help me with just theory portion, minus exact layout. From what I understand the incoming shore power goes to an automatic switch that switches between sending Generator AC Or Shore Power AC to the RV AC supply bus (powers the Tvs, Microwave and AC Outlets, Water Heater, Air Conditioner Heater, and house battery charger inverter. The DC bus is always connected to the batteries that powers the DC Bus for the house led lights, fans, water pump, and 3-Mode Refrigerator. I would still like to figure out how to disconnect the batteries when the power station is providing the AC to the RV inverter for the RV DC Bus. Thank you.
I guess the simplest way would be to put a cutoff switch on the batteries.
But you don’t want to disconnect the batteries or you may have issues. Not sure the converter would be able to run your 12v functions without the batteries.
i guess one way to shut down the converter and run off batteries while running on the power station would be to pull the fuse or breaker for the converter. Not sure what ramifications there would be…depending on how long you want to run without it. And does it also serve an inverter function?
I still feel that there would not be much draw if the batteries were topped off….
Rich
Rich
Finally got through to the THOR Motor Coach support electrician. He sent the attached electrical diagrams for my 2021 Thor Compass. A better picture to assist us. He also stated no issue plugging the power station into the wall outlet or shore power cable, but need to make sure the power station is capable of delivering 30amps. Also, there is a battery disconnect switch which allows the batteries not to be charged by shore power and only charged by the two solar panels.
Rich,
Do you see any schematics that details the AC to DC converter circuit that supplies power to the house lights water pump, water heater, furnace, and fans? Thank you.
I havent read this whole thread yet, but my son just picked up a good used Mercedes (made by Tesla) battery for $3400. New it was 35.75 kwh. Currently hovering around 35.24, so over 98%. It‘s also liquid cooled, accounting for its longevity, and the configuration is usable just the way it is, and a cooling system can easily be fabricated and added to help maintain its useful live. Nissan Leaf batteries used to be the standard, but this thing is a significant improvement over them. I dont know what the 2kwh Li-ion power station mentioned above costs, but this thing is the best $/kwh I’ve ever seen - by far!
Also (on topic) I fully agree with others here that back-feeding a power source into an RV would be a mistake that could lead to some very serious consequences (do you have a 30amp outlet on the coach to back-feed it into?) and even wired correctly, it wouldn‘t be worth doing for 2Kwh.
