Disconnect refrigerator
med2055
Thor
Challenger
Ford
7.3 gas
Ranger 4x4
I have a 2022 Thor Challenger. I have tried to find disconnect for refrigerator when storing. On breakers off , still power. Only way is to disconnect battery, is this normal ?
Not normal. Should be a breaker. The installers may have used a inline fuse somewhere? It is not appropriate, but I have seen worse.
What type of refrigerator is it? Can you find where it's plugged in?
It is a residential style ..behind the unit is the plug in, not easily accessed
Can you attach a picture of your circuit breaker panel?
There are some inline fuses in the battery compartment..I may try to identify
Highly unlikely that a 120VAC residential fridge would have an inline fuse - it's most likely protected by a circuit breaker in the power panel, or a sub-panel somewhere.
I thought He has 12V refrigerator since was talking about disconnecting the battery.
Disconnects inverter. All breakers are off.
In post #4 he said it was a residential refrigerator...
all breakers are off..no sub panel
Since it's new you should contact the dealer, etc. It sounds like it's not wired properly.
