What's the hottest weather you've traveled or camped in?
bpaikman
Lake Jackson, Texas
Ventana LE 3436
35 feet
Cummins 340 hp
I was reviewing our upcoming trip in mid-August and we'll be spending our second night at Copper Breaks State Park near Quanah, Texas.
I was looking at the weather app today ....it says all this week it'll be in the upper 100s ....I'm seeing temperatures at 107, 108....😬. we'll have 50 amp hookups, but arriving 3 pm-ish. Yikes. Hoping it will be raining Aug 14.
Can our 2 AC's handle it?
Right now we're sitting at ppl in Houston while they fix a minor issue - 90 degrees, no big deal.
Insulation pillows with reflectix in your ceiling vets, Magne Shades on windshield, entry door, and cab windows. Reflectix over shower skylight.
I also put a rubber weatherstrip around the entry door to help reduce heat exchange around the door.
Did I miss anything?
To answer the question 95 degrees with 85% humidity. But that was in a 30 ft class C with only one A/C. I had to leave the air dump vent open to get to 74 degrees inside, and the A/C ran continuously from sun up towel beyond sun down.
Hottest!! Just recently, in Ogallala Nebraska, July 10th & 11th, was 106 degrees!
Magnashades worked great!
Set thermostat for 73 degrees, and stayed 73-75 the whole time!
Got to love the insulation in a Newmar!
I know I camped in 100 degree + weather but that was in my Itasca Meridian. The old AC's couldn't keep up. Right now I am in Wilson Kansas, temp outside is 95 degrees. Temp in front of coach is 74 degrees with both AC's running.
yikes --checking out magnashades
Magneshades sound like a lot of work and expense for 2-3 days. We have the Newmar parked outside our house now, hooked up to 50 amp, both A/Cs. 92 degrees ('feels like' 104 - due to humidity). Perfectly comfortable ins the motorhome, with just the shades.
We're still thinking. It could be 15 degrees hotter in Quanah
The key here is to get a jump on the heat by running the generator while traveling and have both a/c’s on. When you get to your spot the coach will already be cooled down.
Yes, I don’t use them for really short stays, but then I never tried 104 degrees. Fir a short stay, in that weather, I would likely keep all of the shades closed.😎
I was thinking the same. And the cab AC ....is pretty good... We took the coach back to storage place just now, 15 min drive, and the cab AC was too cold for me.
agree....
I was just remembering that we drove up to see the August 2017 eclipse and spent two nights driving out of Texas, mid-August, we didn't even think about the heat issue. Different coach...basement AC
Our record is 108 degrees in Baker, Oregon. Low humidity, parked in a shady site under trees, and a grass lawn between sites. Kept the shades drawn.
The AC kept the rig around 80 inside. T-shirts and shorts. It was OK, not miserable. Cocooned inside during the worst of the afternoon.
Fighting fire as a Hotshot Captain I had 122° wearing full gear. But I was younger then...
