- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
In light of the current COVID-19 pandemic it's especially important to have clean filters in your RV. For those that may not know your roof air conditioners have filters most likely like my Newmar does by pulling down the magnetically held trim cover (wood panel for me). I typically vacuum them out and if necessary wash them with water and let air dry. I have a spare set of the filters if needed which also helps in rotating them for cleaning.
Water filtration is also a good idea, keep those filters changed frequently. I do mine quarterly needed or not. I have various ones from .5 micro to 1 micron as I use a dual filter system for sediment and carbon filtration. Now is a good time to ensure you have the 0.5 micron filters in use. I highly recommend the simple mod to a cost effective dual filtration system that I switched to a year ago and it works great.
Beech Lane External RV Dual Water Filter System: Amazon.com: Beech Lane External RV Dual Water Filter System, Leak-Free Brass Fittings, Mounting Bracket and Two Filters Included, Sturdy Construction is Built to Last: Automotive
Watts MAXVOC-975RV 0.5 Micron Filter Cartridge: https://www.amazon.com/gp/product/B002UC6NIE/?tag=rvf01-20
