- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
But why?This owner went directly from delivery to the beach. Ouch.
I never take my bus on grass after I was told by Marathon it’s a very bad idea with the weight of them. I am surprised how many people do it and they are able to drive away without getting stuck. This owner went directly from delivery to the beach. Ouch.
I wish I knew. Stupid is stupid does? New owner ignorance? Thought it had 4 wheel drive? Wanted to redefine glamping? All possible answers.But why?
This is my main problem with Class C RV's. The rear axle is almost always way too far forward. I know they do this so it can have a better turning radius but it is not the proper way to spec out a chassis. They are probably also cheating the rear axle forward so it unloads the front axle some because it's probably too small for the application. If the rear axle was back where it was supposed to be the front axle would probably be overloaded. (I'm almost sure of it). In other words an E-350 chassis probably isn't the right chassis for an RV of this length. But they made it work. Sort of..............Man that’s a seriously long rear overhang. No wonder they had a problem.
In addition to these money saving reasons, if they use a standard chassis length they don’t have extra cost for extending the chassis nor the extra weight from the extra frame, which would reduce the CCC.This is my main problem with Class C RV's. The rear axle is almost always way too far forward. I know they do this so it can have a better turning radius but it is not the proper way to spec out a chassis. They are probably also cheating the rear axle forward so it unloads the front axle some because it's probably too small for the application. If the rear axle was back where it was supposed to be the front axle would probably be overloaded. (I'm almost sure of it). In other words an E-350 chassis probably isn't the right chassis for an RV of this length. But they made it work. Sort of..............![]()
I prefer "live and learn"I wish I knew. Stupid is stupid does? New owner ignorance? Thought it had 4 wheel drive? Wanted to redefine glamping? All possible answers.
I'd say an E-450 would be much better suited for this application but would increase the cost of the RV by $5000 or so. But why use the correct chassis with axles heavy enough to carry the load when you can create this dangerous mess you see in the picture?In addition to these money saving reasons, if they use a standard chassis length they don’t have extra cost for extending the chassis nor the extra weight from the extra frame, which would reduce the CCC.
