- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
Trivial it seems...right? Most of us with sani-con try to get the gray fluid out after dumping and getting ready to pack up and leave by wiggling the hose to walk the water out. Doesn't work! It's not like the stinky slinky as there seems to be a vacuum lock or lack of venting with sani-con. What does work is if you turn on the sani-con and then do the wiggle and even better would be to leave gray open so there is a vent source. Once the fluid comes out then turn off your sani-con and if you opened gray make sure to close it. Again, sani-con off and gates closed will NOT get the water out of your sani-con hose, in my experience.
