chassis wiring diagram
Glennbob1951
Abilene Texas
Monaco
Windsor
40’
Cummins 330
2013 F150 4x4 Lariat
I have a 2000 monaco Windsor
Am needing the chassis wiring diagram
You would have your best luck if you ask on the Monacoers.org forum. There are many electrical diagrams there but not sure if one for your Coach is there
Still learning the site Thanks
Do you have a specific issue that you are trying to resolve?
Yes. 1999 Monaco Windsor. While driving down the road. Lost all 12vdc power to front drivers side electrical compartment
The 12vdc post in back passenger side electrical compartment that’s marked front chassis 12vdc has power. So between the 12vdc feed from back compartment to the front drivers side electrical compartment. I’m not getting 12vdc.
Post your issue on the Monacoers site also. A bunch of very knowledgeable Monaco folks there
I would check the circuit breakers in your rear run bay. Not sure how a 2000 coach is payed out but on mine there are lever type breakers in the rear and I would imagine one supplies power to the front bay
This is what mine look like
The 12vdc post in backside electrical compartment. Marker to front electrical compartment has 12vdc. When I go to front electrical compartment there is no 12vdc power to post.
Is there a junction box between the back electrical compartment and front electrical compartment?
Thanks
Does the automatic transfer switch have anything to do with 12vdc? When on shore power my inverters led light turns red. Indicates an over charge. When I start generator the inverter led light turns green
Indicates normal operation?
do you have a 12v meter in your system? If so, what does it read when running the engine, on shore power, on generator?
I installed one similar to this in my dash primarily so I can see the status of my batteries while boondocking at a glance but it can also tell you what’s going on while on different system’s. This sight is terrific with a lot of great folks here but I would also highly recommend you get on the Monacoers.org site. A lot of folks there with your vintage Coach that are more knowledgeable about the electronics than me.
