- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I have been towed twice in 17 years. Both times the tow truck drivers were very experienced older drivers who removed the drive shaft instead of removing the drive axles. They both said that even though it is more difficult to do, especially on the side of the road, they always tow this way. It certainly is less of a mess. If it were me, I would ask the tow driver to drop the drive shaft and not pull the axles.Figured they would - I plan to get a set to carry in the coach but I guess most big-rig tow trucks carry them.
Thanks JimCongratulations on everything falling into place, that could have gone a whole different direction.
I've been towed once. Got an idiot recommended by coachnet. 16000 dollars damage and a lot of aggravation.I have been towed twice in 17 years. Both times the tow truck drivers were very experienced older drivers who removed the drive shaft instead of removing the drive axles. They both said that even though it is more difficult to do, especially on the side of the road, they always tow this way. It certainly is less of a mess. If it were me, I would ask the tow driver to drop the drive shaft and not pull the axles.
Thats why I had some otherwise unnecessary work done like changing the belt at 50k and checking the water pump, etc. With a rear radiator its the kind of work I dont want to do myself, and I dont want my coach on the hook either.I've been towed once. Got an idiot recommended by coachnet. 16000 dollars damage and a lot of aggravation.
I'll get a mobile first and then insist on a low boy trailer next time.
What pump is this exactly? When I mentioned "water pump" with FL-Gaffney today for possibly replacing mine as I'm approaching 60K they said it's a "house builder part". I replied I'm not talking "water pump for the house but the one for the coolant for the engine" - they again responded that this is something Newmar installs. I need to know more specifically what to ask for to have pre-emptively replaced to avoid the above situation.We were out of the shop at 9:45 with an invoice of $880. The pump was about $350 and the rest labor, extra small parts, fluids and taxes. Not bad.
I asked to see the failed pump.
The center bearing totally failed and the shaft was cocked to one side. The visual inspection the same morning did not give me any indication that something is failing, like weeping or wet spot on the engine.
What surprised me was the impeller. It is made of black plastic with the strength on Tostitos corn chip. The blades were breaking off with little effort just using my fingers (photo).
The pump is not rebuildable and basically trash. I feel component like that should Last more than 60K miles. Specially in light use. I always cruise at 65 max.
That’s the end of another chapter. Slowly heading South to Florida.
They were confused. This is an engine part from Cummins plain and simple. I’d tell them its the one thats run by the serpentine belt on the front (well back in our case) of the engine. They probably just don’t get that request very often, if at all, so they were thinking pumps other than the engine water (coolant) pump. But that is odd….What pump is this exactly? When I mentioned "water pump" with FL-Gaffney today for possibly replacing mine as I'm approaching 60K they said it's a "house builder part". I replied I'm not talking "water pump for the house but the one for the coolant for the engine" - they again responded that this is something Newmar installs. I need to know more specifically what to ask for to have pre-emptively replaced to avoid the above situation.
