team bradfield
RVF Expert
- Nov 9, 2022
- Dutch Star 4081
- 40'-10"
- Sparten
- 450 cummins
- 2022 Grand Cherokee
In addition to the switch and the plug in the engine compartment, you also have a breaker that has to be turned on. Our Newmar tech told me to leave it turned on any time the temps were at 40 or below.I'm plugged into shore power, I assume all I need to do is flip the switch in the OH cabinet to turn it on, should I leave it on all the time?
That seems kinda redundant, plugged into shore power and plugging in the engine block? Salesman (I know, salesman) said I didn't need to do anything but hit the switch on shore power, boondocking use the genny, he didn't show me a engine plug in, I will have to look for it when it gets a little warmer, not going anywhere soon, its below 20f today and windy, brrrr. Should be 40's by WednesdayIn addition to the switch and the plug in the engine compartment, you also have a breaker that has to be turned on. Our Newmar tech told me to leave it turned on any time the temps were at 40 or below.
You fall into the ”new system” categoty. You would just always leave yours plugged in, use the switch, on or off as needed, and not worry about the rest. The plug (and outlet) are near the engine, either in the compartment just forward of the radiator or in the passenger side rear compartment. There is not an external cord that you plug in somewhere. Or maybe the newer rigs don't even have the plug, since its been made redundant as you observed, and I’d say your had it right.That seems kinda redundant, plugged into shore power and plugging in the engine block? Salesman (I know, salesman) said I didn't need to do anything but hit the switch on shore power, boondocking use the genny, he didn't show me a engine plug in, I will have to look for it when it gets a little warmer, not going anywhere soon, its below 20f today and windy, brrrr. Should be 40's by Wednesday
Newer models of vehicles can start at temperatures as low as -22°F. One official rule of thumb is to plug in your block heater if the temperature drops to 5°F. But to be safer and to ensure a better running engine, it is better to plug it in when the temperatures are below 15 degrees.
As for the length of time to use an engine block heater, anywhere between two to four hours is the recommended time. Again, this would also depend on how low the temperature is. Plugging it in for more than four hours is just going to be a waste of electricity, but it will not harm your vehicle. You could use an electrical plug timer that will activate the block heater plug at certain times. This saves you time and money.
