Don't be this guy.
sanda
RVF Expert
Pueblo West, Co.
Cougar
28'
That would be hard to forgive yourself for! Double and triple check your pre departure checklist! I will be towing my GMC Canyon which has a five or six step process to go thru to place the system in neutral. I was considering buying a Jeep for the ease of tow set up but maybe it is too easy?
Some of us do not care to be part of Facebook and the first link does not work for us.
As part of my check list, after I’m all hooked up, as a last step in the process I get in the jeep and start it up, and let out the clutch with it in gear to confirm without any doubt that the transfer case is in neutral. No exceptions. I don’t know if that’s the same one or a different occurrence, but I saw a story like that last year. I really makes an impression!
We do something similar.
We have a Ready Brute tow bar, which btw, I absolutely hate. Sometimes, no, most of the time, it's a bear to get both arms to lock in. So to be sure that it locks property, Trish walks beside the Jeep and makes sure we're good-to-go. At the same time, she's watching to make sure the Jeep is rolling properly as well.
And on top of what you said one of us stays out by the jeep to check lights nd a good roll with the Jeep.
We tow a 2012 Wrangler with an automatic transmission. With the engine running and transmission in neutral I move the transfer box to neutral and then shift the transmission back and forth from drive to reverse while reving the engine. If the Jeep doesn’t move I know I’m good to go. Always also check the emergency brake.
From the first link...
"You’re going to a link outside Facebook
The link you tried to go to is outside Facebook: Jeep Wrangler Engine Annihilated After Being Towed In 4-Low, Revving To Over 50,000 RPM | Carscoops
Are you sure you want to follow this link?"
The second link works, as well as offering the option to avoid FB.
My link seems to have ruffled some feathers. I am far from a computer expert but thought the information should be shared with our fellow RV'ers. I am not a big fan of FB but find it helpful in keeping up with friends and relatives around the world.
I updated the OP with the link to use to avoid Facebook. All is good...just making it easier to get to the article the OP wanted to share. Thanks @sanda
I've seen this story a few times over the last several months.
My laptop's browser security freaks out over redirects. So I try to do direct links. I actually had to use my cellphone to check out the link (less security). I'm sure I'm far from the only one with a picky browser security. Also, I'm often in FB jail (still don't know why since all I do is repost what is already on FB). Again, I'm sure I'm not the only one. That is why I posted what I did.
I also end up in fb jail from time to time. Maybe I'll see you there sometime.
