TXfreeze
- Jan 6, 2021
- Holiday Rambler
- Endeavor
- Roadmaster
- 350 Cummins
- None
- Yes
So we have a arctic freeze expected tomorrow, expected to last 3 days temps in mid 20’s F and while we have been through them before in one instance in another RV, failing to drain the water heater tank resulted in it freezing and busting. We want to make sure we don’t suffer anymore losses. So what’s best? Drain the water heater completely? Water heater works only on electric, we’re metered, so we won’t be keeping it warm. Also since pipes can freeze, should we disconnect the water hose and leave the city water dripping, like you do at home? If we empty the fresh water tank so it doesn’t freeze up although I’ve been told that doesn’t need to be done, but if we do, than do we use stored water in bottles for sink and flushing? Heat potable water over fire? Also filled up the propane tank but was reading they can freeze too, how much of a concern is that ? Thanks for any tips or suggestions.
