- Jan 19, 2021
- Rosemary Farm, Grass Valley Ca
- Ventana 3427
- Freightliner XCR
- 6.7 ISB 360/800
- 2001 Jeep Wrangler
fyiall level, engine running, pulled the big slides in and tried the bedroom, no luck
Thanks, my back ground is in aviation maintenance and I now teach the discipline to aspiring A&Ps and we cover 45 subject areas so I too tend to want to figure these maintenance issues out or at least be educated about them so as not to be taken on a ride by unscrupulous service providers. So what you are thinking is when your bedroom slide failed your higher amp programmed controller was able to overcome the extra effort to retract the slide?Initially I tried just unplugging and replugging. That did not work. Did some digging online for the KiB node and once I understood the readout I felt confident enough to swap them around and watch the readout for an over current indication which in may case did not happen. For the next several days I had to occasionally swap the 2 KiB nodes but one day discovered both slides worked. I suspect something was stuck in the bed drive cogs... it has now been many deployments and it seems to be fine. Mystery.
KMG Slide Controller Amperage Reading - iRV2 Forums
I noticed that 3 out of 4 slide controllers are flashing the correct motor amperage, but my heaviest slide - passenger side kitchen slide - is flashing 21 and then 35. The controller states that awww.irv2.com
Disclaimer - I have a background in electrical engineering and a few other disciplines ... I tend to eventually work out things out. (or so I think)
