SteveMA
- Dec 31, 2021
- Cornell, Calif
- Mountain Aire
- FL SL500
- X12
- Jeep Grand Cherokee
Initially I tried just unplugging and replugging. That did not work. Did some digging online for the KiB node and once I understood the readout I felt confident enough to swap them around and watch the readout for an over current indication which in may case did not happen. For the next several days I had to occasionally swap the 2 KiB nodes but one day discovered both slides worked. I suspect something was stuck in the bed drive cogs... it has now been many deployments and it seems to be fine. Mystery.
www.irv2.com
Disclaimer - I have a background in electrical engineering and a few other disciplines ... I tend to eventually work out things out. (or so I think)
KMG Slide Controller Amperage Reading
I noticed that 3 out of 4 slide controllers are flashing the correct motor amperage, but my heaviest slide - passenger side kitchen slide - is flashing 21 and then 35. The controller states that a number of 0-30 is the amp reading...Any ideas??? Did I have a spike of some sort? Hoping this...
