1Hurrican
- Dec 28, 2022
- Boiling Springs SC
- Thor
- Nurricane 34R
- 34 ft.
- F53
- Ford V10 with 3valve engine
- 2002 Jeep Liberty
A lot more noise. On my 2010 E450 it was so loud under full throttle you could barely talk over it.All the testing I've seen on Google shows no advantage with CAI but they do make more noise if your into that.
That was one of my goals - to reduce the constant down shifting and make it pull a little longer on a higher gear on grades. With 5 star, Banks, and a free-flow intake (forget which one) I made some real progress, but when running full throttle up a hill the intake was loud.I opened up my air intake. The one thing I noticed when on the highway is the transmission held it's high gear longer with out shifting down. Not long enough to record MPG.
With those upgrades what was your MPG increase?That was one of my goals - to reduce the constant down shifting and make it pull a little longer on a higher gear on grades. With 5 star, Banks, and a free-flow intake (forget which one) I made some real progress, but when running full throttle up a hill the intake was loud.
When I first got my Georgetown, it got about 6.5mpg at 55 mph. I made some modification to it and now get 8.5 to 9 mpg at 70 mph on my last trip of 2500 miles. I drive the same route a couple times a year to our "GO TO PLACE. "Thanks for all your input. For a starter I am going to do a cold air system, upgrade the exhaust to a performance type, get a tuner, and look into the Airtabs, semi truckers reviews are saying they reduce drag increasing there MPG. I have seen a couple on coaches, but not able to talk to the owners. Any other suggestions.....
