Green water with city water hookup
Embald2
Hi! Occasionally when I flush toilet or run bathroom sink slightly green water will come out and then clear up rather quickly. There is no stored water in fresh water tank. Just curious if I need to sanitize water system? And how? New filter was put on less than two months ago. Thanks for any advice!
It is a fleetwood advantage 2011.. it is def older but has been kept up with.. I also am new to this this is my moms travel trailer and I’m just trying to learn as much as I can
It does happen occasionally in the kitchen sink but not as often
I would definitely sanitize the hose and the rigs system. The easiest way is to buy an In Line Sanitizer. They are specifically for this purpose and only cost approximately $30. Otherwise 2 oz of bleach per 15 gallons of water works. Run it into all of the lines and let it sit for at least 4hrs then flush
I have looked up how to sanitize the hose but could you send me a link for a in line sanitizer that is good.. or please give me the specifics with the bleach
Here you go.
Just be sure to install it before you fresh water hose so that your hose gets treated also.
There's also the possibility that there is a short section of copper tubing or a copper fitting somewhere in the fresh water lines. The corrosion of copper freshwater plumbing can cause the water to come out blue or green and is often accompanied by a metallic taste.
